Horse people- manure spreader
   / Horse people- manure spreader #1
mred2
Platinum Member
West Alabama, USA
iseki tl3200, JD 450H dozer, LS XR4150, Genie Z34/22N lift
I just purchased a used millcreek manure spreader, model 50. I understand that it has not been made for about 20 years. I can get parts from Millcreek, but I think they may be a little high. I am needing a PTO Shaft. It has a 1 in yoke and is about 60 in long. About $266 from millcreek plus freight. Anyone have any ideas where I can find one. Most shafts have a 1 3/8 yoke or bigger.
   / Horse people- manure spreader #2
PTO shafts are available from any farm store if you just need a replacement. They are also available from a variety of sites like agrisupply. Just match to your needs.
   / Horse people- manure spreader #3
1 in yoke on both ends?
   / Horse people- manure spreader #4
The tractor end would almost definitely need to be a standard 1 3/8 6 spline yoke. The end that goes into the implement may be a custom end. I know my old JD cutter uses a keyed shaft on the implement end and not a 1 3/8 6 spline connection
It has the standard 6 spline on the tractor end and a 1 in bore with pin on spreader end. I can find a lot of smooth bore 1 3/8 and 1/12 on the attachment end but not a smaller one. I can buy the yoke end by itself and put it on a new pto shaft, But then you have the cost of the shaft, the price of the yoke and the time. It might be best to pay the $266 for the OEM. I don't see anything on Agri Supply with a 1 in shaft, This is a longer shaft but smaller hp. Most likely 20 to 25 hp at most. I think the compressed length is about 60 inches.
cglaser, that would work. I will have to check if it would save any money over buying the OEM.
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
50ft Fuel Line (A51573)
50ft Fuel Line...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
