Horse drawn plow converted to 3pt!?
   / Horse drawn plow converted to 3pt!? #1
sam2145871
Has anyone on here converted a horse drawn moldboard plow to a 3pt version? I have two 1-bottom Peerless 14" moldboard plows that I found and was hoping to be able to use them. Can anyone see any disadvantages to doing this? Thanks in advance for any responses.
Marcus
   / Horse drawn plow converted to 3pt!? #2
You maybe able to sell them as antiques, buy a 3pt and have money left over?
Yeah I thought about that...I may be doing that. Thanks!
Marcus
   / Horse drawn plow converted to 3pt!? #4
Put a fellow on the plow seat and hook up. Don't bother with the conversion.:D :D :D
Not a bad idea except that its the kind with two handles...a walk behind model.
Now that I've been looking around I think I'm going to try and put both plows together and make a 2-bottom. I have a 70hp 4x4 SAME tractor so power to pull isn't a problem. I just wish I had a regular 3pt 2-bottom to take measurements from. We'll see how it turns out. I'll have to take some before and after shots to post.
   / Horse drawn plow converted to 3pt!? #7
I took a moldboard plow off a small garden tractor and modified it to fit my ym1500.
It works great.
Here are some tips:
The angle of the plow as it engages the ground is critical, if the cutting edge is paralell with the ground - it bounces on the surface.
I have never got too agressive with mine, but i would assume it would want to keep cutting deeper, and deeper.
I found that an angle just steep enough to get the plow to cut into the ground works GREAT.
Also the distance between the coulter and the plow seem to have a lot to do with how deep the plow cuts. (the greater the distance, the deeper the cut.)
The top link adjusts the angle of the plow. I will try and post mine in the near future.
Anyway, plowed just over 1.5 acres in only a few hours.
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2020 JOHN DEERE CP690 LOT IDENTIFIER 190 (A53084)
2020 JOHN DEERE...
2018 JOHN DEERE 460M LOT IDENTIFIER 241 (A53084)
2018 JOHN DEERE...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
Unused Delta Crash...
