Horn Question
   / Horn Question #1
alexsbuddy
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
If I install a LS horn and switch on my XG3037, is a horn relay required? Thanks.
   / Horn Question #2
To the best of my knowledge any horn that I have seen installed either on a car or tractor has always used a relay so I'd suggest using one.
   / Horn Question #3
If amperage draw of the horn is less than the current rating of the switch, then No.
   / Horn Question #4
The stock LS horn on my XR4155HC is wired direct to the horn switch i.e., no relay. My XR4046HC was same.
I’m replacing the stock LS horn with a Stebel air horn that will be powered thru a relay.
Amazon.com: Stebel 116919 - Nautilus Compact Mini Air Horn Black: Automotive
This horn has current draw of about 18 amps @ 12 volts. It comes with a 40 amp relay.
I’ve installed one on my Polaris Ranger and it’s really loud.
   / Horn Question #5
Is there really a need for a horn on a tractor? I noticed one on my tractor and thought it curious.
   / Horn Question #6
   / Horn Question #7
I dunno , but the misses thinks that if she has a horn, she could get my old dog to move- which I doubt!
   / Horn Question #8
If you have helper and try to get there attention, I use it with my wife:laughing:
   / Horn Question #9
I added a horn to mine awhile back, it's very handy for getting the wife's attention from a distance and mostly for getting livestock outta my way.
   / Horn Question #10
I guess I'll try my horn...if it sounds fruity I may be forced to get a air horn too. A tractor should not sound like "Herbie, the Love Bug"! Maybe a nice train horn.
   / Horn Question #11
:thumbsup:
   / Horn Question #12
   / Horn Question #13
Haha! I just went out and tried it...the sound is somewhere between Herbie and the Road Runner. There will be a new horn in my future.
Side note: The keyed switch is spring-loaded to not stay in the auxiliary position (turned left). Is this normal and for what reason? The dash lights and there is lots of relay noise. I didn't want the glow plugs cycling, just to try the horn.
   / Horn Question #14
Wish I still had my Roadrunner horn and the car it was attached to!
   / Horn Question #15
Yep, my AHH-OOO-GUH horn was sold with my '63 T-Bird last year. I miss them both.
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2500 GALLON WATER TANK W/RELEASE VALVE (A60430)
2500 GALLON WATER...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
