Horiz. draw bar hole spacing
/ Horiz. draw bar hole spacing #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
I got my EZmover hitch, but the holes don't line up with my horizintal draw bar. What is the spacing supposed to be? I don't know which one is messed up (though I suspect it is the Hdrawbar I got at Farm&Fleet.
Cliff
/ Horiz. draw bar hole spacing #2
The one I purchased from Agri-Supply has the holes 2" on center. The holes are 3/4" dia.
/ Horiz. draw bar hole spacing #3
is your drawbar the standard 26" width, or is it one of the narrow 20" ones that some of the itty bitty tractors use for the nonstandard 3pt?
</font><font color="blue" class="small">( is your drawbar the standard 26" width, or is it one of the narrow 20" ones that some of the itty bitty tractors use for the nonstandard 3pt? )</font>
26" I have a standard 3pt Cat 1
Cliff
</font><font color="blue" class="small">( The one I purchased from Agri-Supply has the holes 2" on center. The holes are 3/4" dia.)</font>
OK, that's what I suspected. The holes on mine are 2 & 1/8" on center. That sucks raw eggs. I had plans for today that included that hitch. It just didn't occur to me that it wouldn't fit. Never thought to check that until I was ready to use it. I'll have to get another H-drawbar and measure it in the store this time. Live & learn.
Thanks for the help.
Cliff
/ Horiz. draw bar hole spacing #6
if your only talkin an 1/8 inch off then cant you just mill the hole a little bit, like make it a bit of a slot instead, or if you dont have access to a milling machine then you could probably get away with torching it, or a die grinder with a carbide bur or grinding stone, or even filing it since its not that much metal to take out, or you could drill it out to 1 inch and use washers but that wouldnt be the prefferable way in my opinion
Markct,
I don't have the necessary tools to widen the hole. In any case, I don't mind getting one to dedicate to the EZhitch, and the one I have can be used just fine for just about anything else. It just annoyed me because I wanted to use it TODAY. Farm&Fleet is 40 minutes each way. I'll go get another one on a rainy day.
Cliff
/ Horiz. draw bar hole spacing #8
The 10 year old one that I have had the larger space between the holes. So, I had the same problem with my new EXmover. However, the exact same drawbar from the exact same manufacturer which I just bought has the 2" spacing that fits my new hitch perfectly.
/ Horiz. draw bar hole spacing #9
I had the same problem. A few minutes with a Dremel and grinding stone on the E-Z Mover took care of it. A little off of each side and it bolted right up.
Rodger
/ Horiz. draw bar hole spacing #10
</font><font color="blue" class="small">( I had the same problem. A few minutes with a Dremel and grinding stone on the E-Z Mover took care of it. A little off of each side and it bolted right up.
Rodger )</font>
The wide ones may have been metric, 19mm holes, 54mm on center.
/ Horiz. draw bar hole spacing #11
yea metric would make sense, seems these days everything is metric, not a bad thing just a pain since we still are somewhat sae in this country
/ Horiz. draw bar hole spacing #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I had the same problem. A few minutes with a Dremel and grinding stone on the E-Z Mover took care of it. A little off of each side and it bolted right up.
Rodger )</font>
The wide ones may have been metric, 19mm holes, 54mm on center. )</font>
Never though of that! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2018 John Deere 310L EP Backhoe (A63109)
2018 John Deere...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
2018 John Deere 8345R MFWD Tractor (A63109)
2018 John Deere...
