Hopper Hoe???
/ Hopper Hoe??? #1
D.H.Farm
Has anyone heard of a "Hopper Hoe, a hole revolution in digging", 3point backhoe attachment? I acquired this thing and I think I can make it work on my Ford 1510, but I am not really sure how to hook it up. Any info would be helpful. Thanks
/ Hopper Hoe??? #3
Google turns up nothing. Pictures or a link would help alot.
/ Hopper Hoe???
Here are some photos.
/ Hopper Hoe??? #5
That's very unique!!! I have no help for you but will watch what comes of it. I like the; "I acquired this thing" comment :D Do you think it was made commercially or did someone weld it together... ...after a few beers :)
It looks like the out riggers are somewhat "fixed" and are either attached in the down position or up? Does not seem to have been used much.
/ Hopper Hoe???
The out riggers are fixed. It seems to me it was manufactured, but it could be a DIY rig.
/ Hopper Hoe??? #7
Looks like it's styled after a towable unit. If you replace those big loose bolts with lower lift arm attachment pins can you pin the forward tube to your drawbar somehow? The connection will have to slide when you operate the lift arms.
/ Hopper Hoe??? #8
Dear D.H. I own and opperate a Hopper Hoe. I was helpfull in thier design "back in the day". (It never took off by the way.) Designed as as towable trencher, The first modles were "seated". A five lever operation system was hydro. with a LoveJoy coupling to the pump. Normal operation was by a Michigan single cylinder motor. Parts are still available for ALL models! They were built in Bakersfield California. What EVER you do, DO NOT throw it away.
I will try to post a Vid on YouTube if you wish. Beau... (beau_miller@ymail.com)
/ Hopper Hoe??? #9
Beau, I indeed do own a tow behind Hopper Hoe! Could you please advise where parts are available. I am in desperate need of a hydraulic filter. It also suddenly lost had pressure-so maybe a had pump also.
Thanks Mike, Bouse Az
08renegade@yahoo.com
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2012 Chevrolet Impala Sedan. (A66738)
2012 Chevrolet...
2025 Swict 60in Bucket Skid Steer Attachment (A66734)
2025 Swict 60in...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
