Hope This Flail Mower Doesn't Live up to its Name
   / Hope This Flail Mower Doesn't Live up to its Name #1
Suburban Plowboy
FL
Kubota L3710
Finally got around to putting the new flail mower together. It's a BCRL155. I received this thing the second week in August, and it has been sitting here in a crate. The tractor had problems. The new used Kubota mower had problems. The utility cart had problems. Plus it was August, so I didn't want to work any more than I had to.
I cut up the crate with a sawzall, and now I am trying to put the mower together.
Interesting thing: I ordered this from Victory, and the crate says Novatractor. The mower itself says "Bowell." I'm not sure the Chinese are competent to come up with appealing European-sounding names. Someone needs to tell them what a bowel is. I'm going to take the mower off my driveway and try it in a pasture. That will be a Bowell movement.
It looks surprisingly good.
The manual is hideous, but I found a much better one from Tar River Implements, which I will upload.
That's my wife's shadow. She bronzed for the East Germans in the 1988 Olympics.
25 10 21 victory bowell novatractor BCRL155 with top of crate removed small.jpg
  • BCRM Flail Mowers_0.pdf
   / Hope This Flail Mower Doesn't Live up to its Name #2
Well, I hope your bowell moves & mows without trouble...
Thanks.
A couple of the bolts need to be tightened up. Once that is done, I doubt I'll have any reason to worry about a loose Bowell.
The W.R. Long rear remotes I installed are too zippy for my taste. The mower tilts and extends way too fast. I may have to read the manual. I hate to go to extremes like that.
Okay; just checked the manual, and it's not helpful. This is a problem, because an overactive Bowell can have serious ramifications, especially at my age.
There is an adjustment valve on the tilt cylinder. It does nothing until I crank it way down. Then the flow is very slow in one direction and very fast in the other. There is no adjustment valve on the other cylinder.
What do most people do when they have this problem with their Bowell?
   / Hope This Flail Mower Doesn't Live up to its Name #4
Pepto bismal
Flow restrictor that restricts in both directions will keep semi consistent in both directions if and repeat IF it is installed in the line that controls gravity movement. Other option is flow control in both lines to cylinder so can control speed individually in both directions.
Thanks for the help. That's what Victory said when I emailed them today. I have the parts on the way.
I look forward to having my Bowell's flow tamed.
My Bowell is still obstructed.
I tried to get restrictor fittings from Bolt on Hooks. They are not in stock.
This has turned out to be a nightmare.
The threads on the Chinese mower are 1/2" BSPP. Nobody in the US wants anything to do with 1/2" BSPP. I can get 1/2" NPT restrictors, but then I have to put an adaptor on the end of each restrictor in order to make it fit the Chinese BSPP hoses.
The male BSPP adaptors were easy to find. Good luck finding a female BSPP/male NPT adaptor, though. I can buy a set of 4 for $105, delivered, or I can wait until Bolt on Hooks gets a new shipment in.
The mower is going to be hard to use until I get the restrictors. It swings very fast.
I don't know why Novatractor/Victory/Bowell used BSPP fittings in the first place.
   / Hope This Flail Mower Doesn't Live up to its Name #7
OK, now all you have is a simple problem of procuring
the fittings you need to take care of it.
Find your local Aeroquip hydraulics or Parker hydraulics
dealer to get the fittings you need. It may take a few days
but you will have them.
The BSP metric fittings of all sizes are very common fittings
used worldwide; and we did not have sense enough to convert
to the metric system.
BE sure to ask them for a bag of the BSP blue dot o-rings for spares.
Thanks for the help, but Bolt on Hooks says they expect to have the fitting I need at the end of next week.
Don't get me started on the stupidity of the imperial system.
I hope to have fiber moving through it forcefully very soon.
TOP WIND SCOOP W/ PARTS & BRACKETS (A57192)
TOP WIND SCOOP W/...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2020 CATERPILLAR 239D3 SKID STEER (A52707)
2020 CATERPILLAR...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
