Hooking up shaver post driver to Kubota BX24
   / Hooking up shaver post driver to Kubota BX24 #1
Pszotak
BX24
I have a bx24 tractor. Also have a shaver post driver. Some years ago I drove one post to if the bx24 would drive a post it bring a small tractor. Well it did drive the post but blow the return line valve seal, I know what I was doing. Does anyone know how or where to hook up the return line to to Kubota?
   / Hooking up shaver post driver to Kubota BX24 #2
Try describing the hydraulic situation and issue better? Do you need a case drain or something?
   / Hooking up shaver post driver to Kubota BX24 #3
The ones I’ve seen have the return line going into the hydraulic fill / dipstick port. One doesn’t want restriction in this line.
   / Hooking up shaver post driver to Kubota BX24 #4
Think he needs an always open line back to tank. Not a valved third function line.
Some adapt the fill plug. Pretty big attachment for a small tractor.
   / Hooking up shaver post driver to Kubota BX24 #5
Adapting the return to the oil plug is best, but yeah, wow, not sure a sub-compact BX24 is the correct machine for the job.
   / Hooking up shaver post driver to Kubota BX24 #6
Man, if it would pick it up high enough to move it, it would be super handy on that little tractor.
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58216)
PALLET OF 15 4X8...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
Electric Utility Cart (A56857)
Electric Utility...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
2386 (A58376)
2386 (A58376)
