hooking up implements
   / hooking up implements #21
I just put the freedom hitch on my BX-1800 and it's not coming off! It's harder than I expected to move the implement piece, so I'll need to buy separate (well, I might share one between the bush hog and rear snow blade :) implement connectors.
Everything fits alright (if you put it on the right way round). It's "oh so easy" to attach/detach. I wish I had done it sooner. There is plenty of lift from the hitch since the freedom hitch is VERY adjustable...
The ONLY problem is front weight. I already have a full set of weights on the front (5x50 lb) and my Woods bush hog is too heavy for going straight up my hill (about 30 degrees). I'm afraid my tiller might be dicey, too... The freedom hitch adds 5 inches backward and about 60 to 100 lbs.
Anyone know whether I can add any MORE weight I'd love to know... Or is this the time to buy a welder and make an attachment for adding blocks of stone or steel on top of the weight I already have :)
I'm also worried about the pto arm on my tiller - if it will be able to reach the extra 5 inches... I hope so -- or I'll be getting an new pto arm!
Monte
i have checked my pto driven implements, and the pto shaft will extend out
enough to hook up to the tractor. as of this date, i have not bought a
freedom hitch, but i still plan to.
accordionman
william l. brown
   / hooking up implements #23
Have any of you guys tried the "Jiffy Hitch" brand? I was comparing them to Freedom Hitch and they looked much better constructed and cheaper.
   / hooking up implements #24
Hmmm, Jon, I haven't used, or even seen, either one; just got the literature from both manufacturers, and I thought the Freedom Hitch looked better and the price difference was very small.
Bird
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
NEW Fork Extensions (A59000)
NEW Fork...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
