pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,348
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
I read this whole thread last night and now again this morning. I was going to "save my breath" but I've had a few hours to think about this.
First of all Harry you make valid points. Who wants to deal with the preventable death of a loved one.
That being said I believe there are times when you have no other choice but to give a vehicle/tractor a boost. I prefer to hook up to the battery posts but try that on a tractor where the batteries are buried under the cab floor. Sometimes it's just safer to hook up directly to the starter.
But you have to think about how you are going to do this. I always double or triple check for gears in neutral or preferably park. Next before you even start the process, in your mind come up with a safety plan if things do go south. Ask yourself what are you going to do if the tractor lurches forward or backwards. Think about where you can safely go. If I hook the booster cable to the starter is there a chance that I'll also touch the solenoid wire at the same time? Is there a chance that the clamps will touch something they shouldn't and cause sparking? Take steps to prevent those scenarios from happening.
I don't like to use a screwdriver to jump the solenoid terminal. I have a remote starter button with about three feet of wire. With the attached alligator clamps you fasten one end to the solenoid lug and the other end to power. When you push the button then the starter turns over. You don't need to be standing right in front of the rear wheel while cranking over the engine. There is enough wire length that I can be sitting in the tractor seat while cranking over the engine. Think about that for a minute. I'm now in a position to control the tractor if I need to. Even though I've checked several times that the transmission wasn't in gear.
If I'm adjusting valves and need to roll the engine over I disable it's ability to start. Leave the key off or pull the shut off knob out and fasten it that way. If it's a gas job you can pull the coil wire. Try to ensure two safety measures. Ie tractor in neutral/park/park brake on and disable starting or remote starting from the tractor seat etc.
Lastly I boost other vehicle/tractors regularly with my work truck. I finally made a boost point on my truck. I have two short battery cables leading to the outside of the truck. There is a plate with two large brass terminals. One black and one red. I don't even need to open the hood to boost something. It's just one less source of frustration which makes the job safer. I should have done it years ago.
