Hooking a bobcat attachment to a john deere
   / Hooking a bobcat attachment to a john deere #1
Bheal
Elkton. MD
John Deere
Our company just purchased a Toolcat 2600 G series with a v-blade and a SB200 snowblower with the 7 pin attachment control. We also have a John Deere 326D Skid loader which we would like to be able to hook these attachments to. The 326D comes standard with a 14 pin electrical connection which only uses 7 pins. Will it work fine to just make a small jumper which just goes from the 14 pin connector to the 7 pin connector?
   / Hooking a bobcat attachment to a john deere #2
You could probably check wire to wire and eventually figure it out. A better idea is to get a hold of the guys over at Skid Steer Attachment, Skid Steer Loaders. They can help you out and might even have a pigtail adapter.
   / Hooking a bobcat attachment to a john deere #3
The bobcat 7 pin harness uses 2 12v power wires, the remaining are grounds and data cables communicating with controller on the attachment. The 12v goes into the controller then depending on button pushed the controller sends 12v to the appropriate solenoid. Standard 14 pin has 1 ground and remaining wires are 12v power from individual switches.
   / Hooking a bobcat attachment to a john deere #4
Our company just purchased a Toolcat 5600 G series with a v-blade and a SB200 snowblower with the 7 pin attachment control. We also have a John Deere 326D Skid loader which we would like to be able to hook these attachments to. The 326D comes standard with a 14 pin electrical connection which only uses 7 pins. Will it work fine to just make a small jumper which just goes from the 14 pin connector to the 7 pin connector?
Check if this will work. You could wire it to a separate connector on the blower, so the 7 pin would still work with the Toolcat.
7 Pin Bypass Kit - 4 (14 Pin) Adapter for Bobcat Attachments to Run on Other Machines | Skid Steer Solutions
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
