Hood hinges on 855
/ Hood hinges on 855 #1
kimodc
Hello, first time poster but have been reading and enjoying for a while now. I do need some help figuring out just how the hood mounts on my 855. I was excited to pick up an 855 W/ 70 FEL that needed a little TLC. The hood was just sitting loose and every way I position the brackets it just won't sit right. I am tired of wrestling with it and any help would be appreciated, maybe even a picture showing how the four brackets mount to the underside of the hood itself. Thanks
Kim
/ Hood hinges on 855 #2
Welcome to TBN:D
Attached is a picture from www.jdparts.com, Is this what you need?
Thanks kennyd, that should work. My rods are a different shape then the ones pictured, but I will see if it mounts up properly. Thanks again!
/ Hood hinges on 855 #4
There are two different serial # ranges listed, I just picked on at random. You can register at JDParts yourself if you want, or I can see if I can help more. A picture of your setup may help also...
/ Hood hinges on 855 #5
The hinges are kind of different on that tractor.
My hinges don't like to lift up.
I have to push forward and wiggle as I lift or they will bind up.
(The hood moves forward as it rises to clear the grill area.)
I can get you a pic but it may be a week or two.
Good Luck,
Glenn
/ Hood hinges on 855 #6
I can send you some pics in two days.
Just need to get them scanned....
If you still need them?
Pictures would be great! I have tried according to the pictures off jdparts and it still won't sit right. Pictures of the real deal just might be what I need!
....BTW 855Idiot, I read your story on how you got your 855. What a find! Congratulations.
Kubota L175 Tractor (A62613)
Kubota L175...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
CAT PC306 PLANER (A65053)
CAT PC306 PLANER...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A61573)
2015 Ford F-450...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
