Hood Decals
   / Hood Decals #1
Anonymous Poster
Epic Contributor
I just purchased a new TC40 with a FEL, and the hydrolic lines on the right side of the hood rubbed off the "TC40" stick-on decals (when I raised the hood). I assume I can order replacement decals from the dealer or from NH, but how can I keep the hydrolic lines from rubbing the hood?
Thanks
CVPUSER
   / Hood Decals #2
You should be able to loosen the fitting where the hoses attach to the loader pipes ( toward the front of the tractor on the upper part of the loader arm ) and slightly rotate the hose assemblies to ensure that they run mostly in the vertical plane. You may have a slight twist in the hose causing an unusual amount of sideways movment.
Make sure you relieve the pressure by setting the bucket on the ground and wiggling the stick through all of the positions a few times.
Good luck !!
Golf Cart (A55787)
Golf Cart (A55787)
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
Auger Drill Bit (A56857)
Auger Drill Bit...
John Deere 4600 (A53317)
John Deere 4600...
