Hood Decals
   / Hood Decals #1
Anonymous Poster
Epic Contributor
I just purchased a new TC40 with a FEL, and the hydrolic lines on the right side of the hood rubbed off the "TC40" stick-on decals (when I raised the hood). I assume I can order replacement decals from the dealer or from NH, but how can I keep the hydrolic lines from rubbing the hood?
CVPUSER
   / Hood Decals #2
You should be able to loosen the fitting where the hoses attach to the loader pipes ( toward the front of the tractor on the upper part of the loader arm ) and slightly rotate the hose assemblies to ensure that they run mostly in the vertical plane. You may have a slight twist in the hose causing an unusual amount of sideways movment.
Make sure you relieve the pressure by setting the bucket on the ground and wiggling the stick through all of the positions a few times.
Good luck !!
Chery 7' 32 Drawer Workbench (A50121)
Chery 7' 32 Drawer...
2000 Genie Z45/25 Manlift (NOT RUNNING) (A50774)
2000 Genie Z45/25...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
John Deere Z994R (A50121)
John Deere Z994R...
2012 Porsche Panamera Hatchback AWD Sedan (A50324)
2012 Porsche...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
