hood cost?
/ hood cost? #1
camillit
Dropped a 30lb rock from bucket onto hood, bad dent. Is hood plastic, metal, fiberglass? It dented hard, must be metal? Searched internet, cant find a hood anywhere! Where are they, what cost?
/ hood cost? #3
What tractor do you have?
Duh. Look at his id. 2305. It's metal. I'm interested too. I was digging out a neighbor's camp at the end of this (epic) winter and had a chunk of ice fall from my FEL and dent my hood. It's really thin (cheap?) :confused2:
/ hood cost? #4
The hood part number is LVA801992. Any John Deere dealer can get one for you for around $750.00. You might find a used one, but they are pretty rare in salvage yards. It is metal. This is assuming it is for your 2305?
/ hood cost? #5
Whb' I am on an android app right now and it doesn't show what he has using this format!
/ hood cost?
$750.00 !!!!!!!!!!!!!!!!!!!!:confused2:
/ hood cost? #7
Being metal, take it to a local body shop, they should be able to pound it out, add a smidgon of bondo, paint it like new.
You will probably need to supply the paint purchased from your tractor dealer for a perfect color match.
/ hood cost? #8
Well, you can try eBay...Deere hoods show up fairly frequently.
Or, pull it off and take it to a body shop for repair/repaint.
Just out of curiosity, why did you have your bucket so high?
/ hood cost? #9
My B7800 Kubota new hood from four years ago was around $500 before you add in the decals.
Only a small ding but my stupidity bothered me so much I just closed my eyes and replaced it.
/ hood cost? #10
I third then idea of a body shop fixing it. And second the using JD paint form the dealer. Other paints will fade quickly or turn blue/green.
Then again, you could pound the dent out yourself and when someone notices, you will have the story of the evil rock to tell :)
/ hood cost? #11
Yeah i have android also with no profiles
/ hood cost?
Good question! Picture this: An inground swimming pool. The pool has a 42" high metal ornamental fence around it. A Koi pond is located in corner, between pool sidewalk and fence. I am eliminating pond, so...after draining there is a lot of rounded stone, rocks, all there when pond was built for looks.
I have to get rid of rocks, rounded smooth rocks and river stone...so...I pull tractor up to fence, hoist fel is above fence, bucket is at about 45' angle.
I load bucket....get in tractor, start, slowly lift fel, move back, AND ON THE THIRD BUCKET LOAD I CURL BUCKET BACK BEFORE I LOWER FEL. hello 20lb rock! Am I stupid. Yes, I know better at 55 years old. Frickin moron I am.
/ hood cost? #14
Another case of Sh*t Happens!!!
You ain't the first guy who moved the joystick in the wrong direction and you won't be the last...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
159115 (A60430)
159115 (A60430)
