Good luck with the Honda. I like Honda products. I've owned a half dozen of their motorcycles in my life time. I had a Honda generator until someone liberated it from garage.
I own an Ariens 1128 snowblower. While it has generally done the job, I have had more problems with it than I think is acceptable. It really doesn't like wet snow, not many snow blowers do, but when the snow gets wet and heavy it burns up the impeller belt. Which is a big hassle at a time when the last thing you need is a big hassle.
For those who are thinking of buying a snow blower I have the following recommendations but keep in mind these are just my thoughts so others may have a different opinion.
1) Get a bigger blower than you think you will need
2) Get a blower that it comfortable for your height. Are you bending over slightly to use it? Your back will hate you after an hour or two.
3) Get a blower with a differential lock on the hand controls. Either have this or have a very strong back because you'll be lifting the rear wheels off the ground to turn around. Or one wheel will be spinning in deeper snow when you don't want it to.
Even if you use fuel stabilizer, turn off the fuel and drain the carb using the drain button on the bottom of the float bowl (The 1128 has this feature). Don't just turn off the fuel and run it until it stalls, fuel will still remain in the bottom of the carb and will cause problems. Do this and the blower will start every time. My four year old Ariens literally started on the first pull of the cord this winter. Also, spray some lube on the cables and other unpainted metal parts. Careful not to get the spray near the belts or the drive speed selector wheel (in the housing under the engine)
