Honda Tracked Snowblower
   / Honda Tracked Snowblower #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
We are in the market for a small Honda tracked snowblower.
All of the reviews I've read have been good.
Does anyone have some drawbacks to a tracked blower?
We will be blowing a very small lot. 150' x 50'. The ground is paved but a little rough in spots. So I was planning on using the high auger setting for those areas.
Any comments?
   / Honda Tracked Snowblower #2
Any comments?
I had a 1987 Craftsman Trac blower, it worked great for years. I never had any problems with traction, the unit was very heavy. I only problem was the disc clutch got stiff from seating every summer and the bottom of the blower housing rusted. I sold it for $50 last fall, but it still did the job,ran good. I think it had 8 or 9 hp tecumseh. Tru-Trac 21" path. I always like the tracks, they lasted from 1978-2013 when i sold it.
   / Honda Tracked Snowblower #3
I have owned many different blowers, both vintage wise and brands.
The Honda, while a little pricier that many, is a good value and definitely a quality product.
Uses real bearings, quality steel and a very reliable easy to start engine.
Tracked is a very nice feature.
   / Honda Tracked Snowblower #4
We have had a 928 for close to 15 years now. Best snowblowers hands down. The only thing Id do different would be to get the 1132 for the wider path. Great traction. They can climb up onto decks to clean them. THe only thing is you have to work with the blower, you cant man handle it. Turns at the end of the driveway are a bit of work. Its too bad they dont offer the steering brakes like honda does on the large models. It throws further and more accurate than the blower on my BX by far.
Thanks for the help guys.
They don't have steering brakes? It looks like the turn easy on YouTube.
You climb stairs with them? You don't worry about the machine rolling back at you?
Sent from my iPad using TractorByNet
   / Honda Tracked Snowblower #6
No steering brakes on the small machines.
They do have a lever that allows you to lift the auger section putting weight on the rear of the tracks (or the auger scraper for icey surfaces). Its not that hard to turn in truth, but it is harder than a wheeled model.
Yes It climbs stairs. I climb a set of 4 to get onto the deck. It climbs them no problem with the track drive. I cant say how they'd climb a particulalry steep set or an overly long one, but in my experice it climbs perfectly fine and Id have no problem climbing a set 2 or 3 times as long at the same pitch as Im climbing now. I climb the ramp into the back of my truck with no issues either and its quite steep (short ramp, tall truck).
Hydrostatic trans is awesome for that. You can dial the speed down to a crawl.
   / Honda Tracked Snowblower #7
We have one of the small honda tracked blowers at work. We use it for clearing walking paths through the plant. Last winter we cleared a drifted path in the tank farm that was deeper than my waste. The only part of the blower showing was the shoot and handles. It was tunnelling its way under and then on the reverse pass we just blew what caved in. It is hard for me to steer and the handle bars feel really low, but being 6'3" May be causing that.
   / Honda Tracked Snowblower #8
I had an 1132 and while it would climb the side of a cliff, I found it cumbersome to maneuver and difficult to turn. I only used it for about 10-12 hrs and sold it. I bought it as a leftover in July and sold it for what I paid for it the following January. I now have a 28" Simplicity signature Pro model that I like much better.
Great info. The Husqvarna has tracks, hydro, and steering brakes. I may give that a shot.
   / Honda Tracked Snowblower #10
I had both the tracked and wheeled version of the honda hs928. I found a deal on the tracked one and used it for 2 years and then found the wheeled one for $400 in the middle of August... They were moving to Florida and it had to go.
I put them both on cl last fall and the tracked one sold first so I kept the wheels.
The tracked one is slower and harder to turn. But it will go anywhere and the ability to adjust the angle of the bucket is nice. It allows you to scrape the pavement at the end of the storm. And also reduce wear on skids and cutting edge when you want to clear the driveway during the middle of the storm. Also very good for going off paved surface.
I was ok with keeping the wheeled for the increased travel speed. When you have less then 6" of snow to move the tracks are to slow.
If I had it to do over again I'd keep both.
2014 FREIGHTLINER CASCADIA DAYCAB (INOPERABLE) (A48992)
2014 FREIGHTLINER...
New Tractor Seat (A47371)
New Tractor Seat...
Landini Vision 105 4WD Tractor (A49251)
Landini Vision 105...
International 500 Transport Cultivator (A49251)
International 500...
Brush Hog Mower (A49251)
Brush Hog Mower...
Ryobi Sliding Miter Saw (A48837)
Ryobi Sliding...
