Honda small engine help
/ Honda small engine help #1
shvl73
Banned
NH
Mahindra 2810HST
I picked up a Honda F220 tiller with a 4 stroke engine. It won't start. It's getting fuel and spark, in fact it'll pop out the carb. I've checked the valves and I don't believe one is sticking. I took the flywheel off to check if the key was sheared and it wasn't. The float appears to shut the fuel off when you lift it but there is fuel present when you take off the air filter.
Any ideas?:confused:
/ Honda small engine help #2
shvl73
when you pull recoil does it have any compression?
I had a 1000w gen that acted the same way the intake valve wasn't closing.
I had to take side plate off motor and pull valve down a couple of times and it has been running it just was gummed up from sitting. i ran it a few minuets and did an oil change ran it about 4 hours and changed it again to make.
tommu56
It does have compression, I think it's normal but I'm not sure. I only took the valve cover off but both intake and exhaust were moving freely. How could I check to see if its gummed up?
/ Honda small engine help #4
if it pops out the carb intake valve isn't closing
try turning valve a couple of times through valve cover
pull plug turn over with pull starter and watch gap on push rod to valve Ill bet there is a little gap between valve and push rod. I think it should bee about .020" normially
put motor in side with valve cover up fill with some pb blaster or kroil liquid wrench let it soak for a couple of hours turn it over a couple of times while soaking.
put it back up right and try again
you could pull head and push valve down and make sure nothings in cylinder
tommu56
tommu56,
Thanks for the help. I've got it soaking with PB Blaster right now. I'll let you know if it works. If all else fails, I'll pull the head. The gasket should be available locally.
2022 EZ-GO ELITE...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A65563)
2012 Mitsubishi...
2017 FORD F-150 (A65643)
2017 FORD F-150...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
