honda rt 5000
/ honda rt 5000 #1
trailgas
honda rt5000
I have a honda rt 5000 tractor. It has always run perfectly and just yesterday it refused to start. I checked the spark and it has none. I put a new plug in and still no spark.
Do the iginitions die on this model. Any ideas?
/ honda rt 5000 #3
I had the same problem at two different times. The 5000 has both a coil and an ignition module that go bad. Also make certain the ground wire from the engine to the frame is good as it can cause the coil and/or module to go bad. They cost about $80 each. Good luck.
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
2014 CM TRAILER ENCOLSED CARGO TRAILER (A63569)
2014 CM TRAILER...
CHEVY 4X4 DUALLY TRUCK BED (A63569)
CHEVY 4X4 DUALLY...
11R22.5 ALUMINUM WHEELS AND TIRES (A63569)
11R22.5 ALUMINUM...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
