Honda GCV160 Carb Float Won't Level
   / Honda GCV160 Carb Float Won't Level #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi All,
I have a Honda GCV160 that the carb float won't level. I tried both a used and new float and neither sits level when installed. No adjustment, so wondering what might be causing this? I changed the needle, as well. Thanks in advance for any help!
   / Honda GCV160 Carb Float Won't Level #2
Can you give us some background on this ?
Why do you have the carb off of the mower ?
Are the new parts from a kit that you purchased ?
Richard
Hi Richard,
Thanks for your reply. This engine was given to me and the previous owner reported no compression. I removed the valve cover and the intake valve was stuck, so freed it and compression was good. The carb leaked, so I replaced the needle, as when pressure tested it leaked air. The float would not install level, so I replaced the float and still, no leveling. The parts were purchased separately, not in a kit. Genuine parts.
   / Honda GCV160 Carb Float Won't Level #4
Did you clean the carb ? If so, what did you use to clean it with ?
Did you used compressed air to blow out the carb ports ? Most carbs have a hard rubber or nylon type seat in the float valve bottom. It is possible that it moved out of place during the cleaning process.
It is most likely that you have the wrong needle valve, too long. Are you sure you have the float right side up ?
Yes, the carb was thoroughly cleaned with soaking in paint thinner and then ultrasonically cleaned. Yes, compressed air was used. I do not see any type of rubber or nylon seat in the needle chamber. I feel the same way about the length of the needle valve; I'm going to double check the part number and see. Thanks! All good points.
After further research on this carb, it seems Honda had two different lengths of needle valves with two different part numbers. When I put the old needle back in, it leveled immediately. The new valve I ordered was noticeably longer. I should have checked that before. Thanks for your spot on input and help! Take care.
   / Honda GCV160 Carb Float Won't Level #7
OK let us know if it works now.
OK, will do. Just ordered the new needle so it will be a few days. Thanks again for your input and help!
Jim
Just a note to update on the latest with this issue. Received a new needle and it fit perfectly! Shorter than the other so the right needle was the problem. Thanks again for all feedback!
Jim
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56435)
2020 John Deere...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
