Honda Foreman cold starting help
   / Honda Foreman cold starting help #11
I run Stabil in my gas most of the year. Doesn't hurt for the little added protection. I have a 450 foreman es and in the winter when I shut it down I always pull the choke out when I shut it down in case I get some moisture on the cable and wouldn't be able to choke it. Mine starts right up and its left outside and usually buried with snow. I have a downpressure plow on it and use it quite a bit to plow snow in the winter. The best thing you can do with any engine is run it regularly.
   / Honda Foreman cold starting help #12
my 00 Foreman has a carb heater on it too. i was cleaning the carb the other in a hurry and pulled the wire out of the harness on the frame didnt think much about it it doesnt get that cold in houston,tx and today went ot start her and she didnt want to it was only about 60 out she always starts before i guess i will hook it back up.:rolleyes:
   / Honda Foreman cold starting help #13
Boiler74 said:
I'm also running the carb dry by shutting the gas valve off if it's going to be stored for a while. Live and learn.
Thanks once again.
Josh
You may not want to run the carb dry. The Stabil will keep the carb clean and the seals wet. I seem to have more problems with a carb that has sat dry rather than wet. Just my 2 cents.
   / Honda Foreman cold starting help #14
beersngars is right, keep the fuel mixed heavy with sta-bil, you'll do better in the long run !!!!! Keep it wet in there ~~~~~~~~
202476 (A54757)
202476 (A54757)
2023 Load Trailer (A55787)
2023 Load Trailer...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
