Honda 250 r spark gas but no run
   / Honda 250 r spark gas but no run #1
trentonford3000
glencoe mn
ford 3000
I have a honda 250 r it is getting gas and spark but wont run. it keeps fowling the plug. so i replaced the plug and the same thing. it doesnt even try to fire not even on carb cleaner
   / Honda 250 r spark gas but no run #2
I don't have much insight. Is the fuel fresh? Was the 2stroke oil fresh?
Is it a quad or a trike? I have an '83 250R trike. I haven't started it in a couple years. It was a fun fast beast. .
   / Honda 250 r spark gas but no run #3
Reed valves bad, Carb gummed up, tank full of rust, lots of possibilities. Have you checked for compression with a guage? What is the condition of the 250R?
fuel oil is fresh I do not know of the condition of the carb but got it to fire on carb cleaner about a month ago and when i finally got to it again it did what its doing no i have not checked the compression and the condition is ok it ran about two years sgo it is a quad
   / Honda 250 r spark gas but no run #5
Compression sounds low. How many hours on the top end?
not sure mmy uncle rebuilt it including the carb and it had a cracked head so that was replaced and hasnt been driven much since
2017 Ford F-350 (A56858)
2017 Ford F-350...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
Portable Restroom (A54865)
Portable Restroom...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A57024)
2014 Doyle Dry...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
