Honda 250 r spark gas but no run
   / Honda 250 r spark gas but no run #1
trentonford3000
Bronze Member
glencoe mn
ford 3000
I have a honda 250 r it is getting gas and spark but wont run. it keeps fowling the plug. so i replaced the plug and the same thing. it doesnt even try to fire not even on carb cleaner
   / Honda 250 r spark gas but no run #2
I don't have much insight. Is the fuel fresh? Was the 2stroke oil fresh?
Is it a quad or a trike? I have an '83 250R trike. I haven't started it in a couple years. It was a fun fast beast. .
   / Honda 250 r spark gas but no run #3
Reed valves bad, Carb gummed up, tank full of rust, lots of possibilities. Have you checked for compression with a guage? What is the condition of the 250R?
fuel oil is fresh I do not know of the condition of the carb but got it to fire on carb cleaner about a month ago and when i finally got to it again it did what its doing no i have not checked the compression and the condition is ok it ran about two years sgo it is a quad
   / Honda 250 r spark gas but no run #5
Compression sounds low. How many hours on the top end?
not sure mmy uncle rebuilt it including the carb and it had a cracked head so that was replaced and hasnt been driven much since
10 x 18 Transfer Auger (A50515)
10 x 18 Transfer...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2012 Toyota Camry Sedan (A50324)
2012 Toyota Camry...
2014 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2014 Freightliner...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
