Buying Advice Homeowner Forklift
   / Homeowner Forklift #111
That would work great for a man basket, where you need to go high but don't have the weight issue. If you have racking, you'd want to put the heavier stuff in the lower tiers anyway, so other than having to swap machines occasionally it should be fine.
Here's my full 8' fork extentions, I wanted to go with RT, but the I beam and a big chunk of 9" flat bar was only $40, so that was an easy decision.
It's great to see someone post mods! Hopefully, some others will do the same. The info all helps in the buying process.
   / Homeowner Forklift #113
We have a set of extensions on the 10k forklift at work, made out of channel and flat bar for the straps and some square stock bent at the back to help hold them on.
The 3pt mounted forklift should be good for about 1500lbs so still pretty capable.
I also use my forklift for maintenance and underside cleaning outside
I also use my forklift for maintenance and underside cleaning outsideView attachment 2158699View attachment 2158700
Did you do any mods to the machine or just add extensions?
   / Homeowner Forklift #115
They are just slip on extensions for when we need them, we also have a decent size tellahandler that we use them on when needed. Work we have a 3700lb, 4000lb, 9500lb and the tellehandler that I think is rated about 8000lbs depending on extension
I was referring to any mods to the hydraulics or drive train too. I'm sure there are plenty of things that can be updated.
   / Homeowner Forklift #117
On the 9500lb on at work? No it's stock, just have extensions for oversized parts.
I don't think there is much I could modify on a forklift safely, aside from cosmetics, and I like to customize my machines!
Interesting, no mods to forklifts. Is this why I can't find much info on forklifts?
   / Homeowner Forklift #119
My little 5k CAT is the handiest machine on the place sometimes
2016 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A55973)
2016 Freightliner...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
(2) MULE PLOWS & FERTILIZER DISTRIBUTORS (A52708)
(2) MULE PLOWS &...
LEINBACH SCOOP PAN (A52708)
LEINBACH SCOOP PAN...
2013 Ford F-550 4x4 Auto Crane 4004EH 4,000lb. 2 Ton Crane Service Truck (A55973)
2013 Ford F-550...
