Homemade Trash Can Carrier
   / Homemade Trash Can Carrier #1
walker450
Platinum Member
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
I built this out of scrap I had sitting around. I didn't have any 2" square tubing to make a receiver hitch but I will get a piece the next time I am in the city. I have it bolted to another receiver just for a test.
To use, tilt the trash can back and sit the front on the upper lip at the bottom. Then push the top of the can forward. The middle of the can will hit the upright and if you push it a little more the bottom falls off onto the lowest piece and the top bar hooks into the C channel. The rear wheels are only about 6" off the ground, but I don't have big hills to worry about so it works fine for me.
To remove the can from the holder, you have to lift it up about 3/4" and tilt it back.
Also, I can lower the tailgate with the holder on the receiver.
Video:
I have another idea to share in case someone wants to build this...
Instead of the C channel at the top of this carrier, install some sort of hook that that can swivel. Push the trash can against it could swivel up and gravity would drop it back down and the can would be hooked. To release, push can forward to take weight off of hook, and lift the hook up enough for bar to clear and tilt can off. This would prevent having to lift the can up and off of the C channel to unload it.
   / Homemade Trash Can Carrier #3
I'm in Japan on the Shinkansen so my precious data plan will take a hit if I play the video. Will look tonight back at hotel on wifi. I could use one of those!
   / Homemade Trash Can Carrier #4
It is short (0.13) shows smooth hookup and removal. I always thought I was in flat country but there are plenty of driveways off crowned roads that would eat the wheels around here. Something that low that far behind the rear vehicle wheels doesn't require much of a dip and rise combo.
   / Homemade Trash Can Carrier #5
that's cool, we had to start taking ours to the house after it was stolen twice.
   / Homemade Trash Can Carrier #6
I have to take my garbage can 800 feet to the road. I tied a piece of rope to the handle that loops over the tow ball when you tilt the garbage can backwards. Then I drive slow, pulling the garbage can to the road. My dad is 81, with failing health, and he can also do this when he's up to it.
   / Homemade Trash Can Carrier #8
Great idea, ....but most Americans really could use the exercise of walking to the end of their driveway once a week (bah-humbug :muttering:) !!
   / Homemade Trash Can Carrier #9
This describes me perfectly. :D
   / Homemade Trash Can Carrier #10
Like Eddie Walker I tie a short length of wire rope between the 2 handles and tow slowly with the trailer hitch.
Since we always have a bungee closure to keep coons out of the trash the lid stays closed when pulling.
Even half full a hill on our drive makes hand towing close to impossible and more so in winter.
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
