Homemade telescoping boom pole
/ Homemade telescoping boom pole #1
imabass
Pawnee, OK
JD 3020 Propane
Here is a simple boom pole for a tractor. Most boom poles are all rigid mounted and do not have high lifting capabilities. This one works like a basic lever and fulcrum much like a engine hoist.
This is different than the standard boom poles for tractors. The standard boom poles are rigid mounted (all the connection points are rigid) and have limited lifting height. There are other poles out there and this is not a 100% original idea but I wanted to construct one to best suit my needs.
The top pole is mounted directly to the tractor top link mount. On the bottom of the pole, there is pin where the bottom triangle is connected. As the 3 point arms are lifted, the pole pivots on the pin and will exaggerate the lifting height of the pole. It is a simple lever and fulcrum design.
The main pole is made from 2-7/8 oil field pipe. Inside the 2-7/8 pipe approximately 30 it is sleeved with heavy wall 2-3/8 pipe. Welded to the 2-3/8 pipe is a piece of 2-3/8 x セ flat bar with a 1 hole for attachment to the tractor top link. On top of the 2-7/8 pole is a simple truss that was made from 1 sucker rod. On the bottom of the 2-7/8 pole is a piece of 2 square tubing with 4, セ pivot holes. Mounted several places on the bottom of the pole are heavy duty D rings for attaching chains for lifting. Also the end of the 2-7/8 pole has optional 2-3/8 extension pole that has a set screw in the side for easy adjustment.
The triangle is made from 2-3/8 oil pipe. Hitch pins are welded to the bottom pipe for attachment to the tractor. The uprights are welded to 2.5 x 3/16 square tubing with a セ hole for attaching to the top pole.
Material cost was about $60. It took about 3 hours to make. Now it is ready to put to work.
Future improvements planned include a hydraulic clamp for grabbing logs, brush, debris, and other things to make working on the tractor more efficient
/ Homemade telescoping boom pole #2
Looks handy! I would be careful relying on just the friction of the set screw to keep the inner telescoping member from sliding back into the outer. Most telescoping engine hoists have a cross-pin that goes through both members.
Noted. The further out on the pole the less weight it will lift. My engine hoist does not have the pins like the one in your diagram. Mine has a set screw similar to my pole. I never have had an issue with that. I agree that a pin is a safer design and I will likely add one in the future. I will probably need it when it get my hydraulic claws/scoop attachment built for the end of the pole for picking up various things like down trees.
/ Homemade telescoping boom pole #4
Same leverage design as post hole digger booms, without the common bent down end.
Bruce
2015 CATERPILLAR 308E2CR EXCAVATOR (A60429)
2015 CATERPILLAR...
UNUSED FUTURE SGB20-20" HYD STUMP GRAB BUCKET (A60432)
UNUSED FUTURE...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
UNUSED FUTURE FTH50-(50) SHEETS OF GALVALUME (A60432)
UNUSED FUTURE...
