homemade plows
/ homemade plows #1
glover
Bronze Member
peterrborough ontario canada
MF 165 and CASEIH JXU90
i have an older 12 horse power craftsman riding lawnmower and the snowblower i have jus tbroek down and i was wondering if anyone has built a homemade snowplow out of like and old steel shovel or a steel drum. <font color="black"> </font>
/ homemade plows #2
glover,
Welcome to TBN!!
Have you looked around for a blade made for that tractor? Considering time and effort to make something, it may be the way to go.
I did a quick look and they're about $200 new with everything. Here's one on e-bay that's currently at $20.
Here is another for $190 with tire chains included.
Brian
/ homemade plows
i would put an offer in but i am only 14 and i have barley any money and i am looking for ways to build snowplows becasue i noi how to weld and i live on a farm
/ homemade plows #4
I see.
Can you fill out your profile and give us an idea of where you live? Heck, I have enough scrap metal laying around but it wouldn't help if you're far away.
What's wrong with the snowblower? Is it scrap at this point? Is there a way you could cut off the sides, remove the chute and auger and use the remainder as a starting point? You then have the mounting system and all you would need to make is a swivel. The rear side of existing blower can be reinforced and made smooth with a piece of tin or something bolted/welded/rivoted (whatever) to the side the snow would contact.
/ homemade plows
yeah i live in peterborough ontario i might find an older broken snowblower part and take the blower and that out and just use that maybe
/ homemade plows #6
I did two things when I was your age with a broken blower. First I built a wooden plow with lag bolts that lasted a couple of years. Then I gutted the snow blower and used it as a pusher type plow.
The blower worked well as a plow because it was only a single stage.
/ homemade plows
thanks yeah we have a BCS multimachine that we made a snowblower for it but it didnt have a properlar that proples it up so i might use that a make a bracket to hold it
/ homemade plows #8
Glover,
Please take note that you have been a sent a Private Message. You should be seeing a flashing envelope just under the TBN Banner at the top of the page. Click on the envelope and read the message please.
/ homemade plows #10
Hey, no problem.
We're happy to help! /forums/images/graemlins/smile.gif
/ homemade plows #12
Here's a LINK to owners manual for a Craftsman snow/dozer blade which should give you some ideas on how to attach to your tractor frame. If you want to try to fix the snowblower and don't have the manual you can go toSEARS PARTS STORE and type in the model number of your blower to get assembly diagrams and parts info.
Good luck
John
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
20ft. Shipping Container (A64047)
20ft. Shipping...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
DELTA  FLARE STACK TRAILER (A63569)
DELTA FLARE STACK...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
2014 KBH 40' Hopper Bottom Trailer (A64047)
2014 KBH 40'...
