Homemade Logging Winch project finally started
   / Homemade Logging Winch project finally started #41
Can anyone tell me what the second shaft above the one hooked to pto by chain is for ,use ect?
   / Homemade Logging Winch project finally started #42
any information about the old ernest holmes winch would help?
   / Homemade Logging Winch project finally started #43
After a long time waiting I finally got around to starting my logging winch project. I have been looking for a used logging winch for several years but they are very expensive if ever come up for sale. So. After seeing some PTO powered winches on Craig''s list I finally bought an old wrecker winch last winter. It has gear driven "in" and "out" and a freewheel option that is engaged or disengaged with a "forked dog" on the main shaft.
I decided to build it starting from a piece of steel plate as it will give me a large surface to mount the winch, drive shaft and eventually the mechanism for the control. I will put bracing on the bottom of the plate as well to prevent it from warping during welding as well as during use.
Here is the first picture with the winch positioned on the 3/8" steel plate. I made the mounting ears (or whatever they are called) out of 3/8" flat bar and the 3 point lower link connection is also 3/8" flat bar. Other then the large plate I had all the steel leftover from other projects. As you can tell some of it has been around the block a few times. But I love not having to pay for something if I can reuse old stuff. The frame that is above the winch just vaguely represents what it will look like, but it is not set in stone. I cut out a couple of pieces and then put it together like that and look at it to figure out the best way I can make the next thing happen. The two ugly looking pieces will probably be welded on the bottom of the plate to serve as bracing.
can you tell me what the top/second shaft is used for on the ernest holmes winch?
   / Homemade Logging Winch project finally started #44
can anyone tell me what the second shaft on the old ernest holmes winch is used for?
   / Homemade Logging Winch project finally started #45
Is it the clutch lever or direction control?
A photo of what you're asking about would help.
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2020 DRAGON ESP...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
