Homemade hiller project
   / Homemade hiller project #1
BTackett
Knoxville, Tn
I was looking at the homemade cultivator thread and decided to post this also. NOTE: I am not an artist but tried to show what I was explaining. This is a Farm Pro cultivator and has removable tines with bolts on the supporting arms. I want to add a piece of 1 1/4 square tubing to the bottom on of the arms after removing the tines and then use the Hillers from AgriSupply and adjust accordingly to what my rows will be. I just cannot see spending the $175+ hillers for ASC hiller hookup when I basically can made my own.
Does this look like it will work? Any suggestions? I guess the biggest thing would be the angle to run the hillers , I could use the top link to adjust this also.
Any ideas or criticism would be appreciated.
thanks,
Bill
   / Homemade hiller project #2
Bill, One problem I might see is ...Are your hillers going to be lining up behind the tractors tires?? If not it might work.;)
They would have to be mounted on the inside of the square tubing. My rear wheels are about 44" on the outside so that leaves me a lot of room on the inside if I mount the bar further back.
Bill
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
