db556
I'm just having a thought, I friend has a rotary plow gearbox(just the gearbox nothing else) that he might give me for free if I can find a cool use for it.
So I'm thinking well drilling rig, I take a 3 foot section of Hex stock bore it out to lets say the OD of 1" black pipe, and weld on a few inches of split tubing on top for a clamping collar. Ontop of this collar I'll mount a wheel bearing so the rollers point up, to the outer race I'll mount either a set of hooks for weights(10-15-25 pound) or two handles for manual cutting pressure maybe both.
For the gearbox I'll mount that on frame going to a section of 3'x3'x3/8" plate I have behind my shed, I'll weld some 1" washers of the corners for some large pins to keep it from spinning it I hit something harder than clay rock.
For the cutting head I have some old PTO yokes I knock the cross out and replace it with a hardened pin from a differential and for the teeth I have some old spider gears. I think the gears will last atleast a 40 feet with the sand/clayrock I have in beaver county.
For water injection I have swivel from a old hose reel that should screw right onto the 1". My 2" harbor freight pump should be able to keep up with the water demand of drilling easy so now its just the question of how deep is the water table at my house?
Project seem cool enough for a free gearbox?
