Homemade Front or Rear Ballast Box
   / Homemade Front or Rear Ballast Box #11
They just looked bigger than that. The beauty of pics:)
I could have swore they were at least 16 x 16 x 8 or so.
Have you put them on the scales??? I bet there still closer to 50-60 lbs each cause concrete retains a lot of water. Cured concrete i think has like a 40-50% moisture content.
I haven't scaled them yet. Maybe later when my wife leaves for the day so I can take the bathroom scale to the garage. ;) They do feel pretty heavy, especially at the end of a busy day.
Speaking of my wife, when I was in the middle of the project she asked me how I was going to make concrete in the middle of winter in Michigan. Before I could answer she said "And don't even think about doing it in the basement."
I asked her when was the next day she was going to be gone for the day.
But I ended up mixing it in the garage with hot water from the house and had the kerosene heater on.
LD1, you're right. I weighed one on the bathroom scale and it is 44 pounds. So it does retain moisture. And there is a small amount of re-rod in it.
GE222, Regarding steering. I was out today and moved it off my trailer and drove it back to the barn to park it. I put it in 4wd Hi Range. There was a dusting of snow on the drive and yard. It steered very easily with the 4 blocks in (250 pounds total on the front).
This is so much better with the extra weight on the front. It was too light before and I was having trouble getting it to behave and steer where I told it with the heavy 3pt blower on the back. I was kidding my wife about just building a seat up front for her to sit on and then I would also have a 'wench' on the front. But she didn't like that idea much.
Also I used the receiver mount with a trailer hitch on it and moved my boat into the recently completed barn. That trailer hitch will be a handy thing to have.
   / Homemade Front or Rear Ballast Box #15
That sure is nice work GP.
Everything is clean, and well thought.
Roger270
Thanks again, guys. It was fun. Went through a few changes on paper before I built it. Next project....(after fluid/filter changes that I'm doing now) ......... Front End Loader!
   / Homemade Front or Rear Ballast Box #17
what size of steel did you use?? i need to fab something up for the rear to have ballast for when i use my fel. any suggestions would be helpful
   / Homemade Front or Rear Ballast Box #19
Nice job I was just listening to the weather and snow Saturday and thinking I need weight in the rear of my 855 reading your post I remembered I had some cement blocks I can run the draw bar through lift the hitch and off I can go. Thanks for thr inspiration
   / Homemade Front or Rear Ballast Box #20
I also recently made the discovery of how well ballast can improve the capability of a small utility tractor. I run a FEL on my New Holland TC40DA so am already running weight on the front axle. I needed ballast on the rear so I fabbed a similar concrete 3pt ballast box. I used some 3/4 plywood that had been laying around to frame it, plenty of screws, and some ingenuity to hold my top link mounting and bottom link mounts with steel I grabbed from the scrap pile.
Turned out really nice, I built it to give 1,800 pounds of ballast using just a hair under 1/2 yard of concrete. Only difference is I took my empty form on a trailer to a local concrete plant and got some left over mix at no charge. I had a cap premade for the ride home so it wouldn't slosh around. Re screeted the top as soon as I got home and let it set for a few days. Used it a few times already, and it's a world of difference. I recommend it to anyone with a FEL and some spare time to fab it up.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A57024)
2022 Schulte...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
202481 (A54757)
202481 (A54757)
2002 Bobcat 763 High Flow Compact Wheel Loader Skid Steer (A55851)
2002 Bobcat 763...
More info coming soon! (A55851)
More info coming...
