Homemade edge tamers
   / Homemade edge tamers
Thanks! I have been contemplating building a set for the rear blade too. I am hesitant because I would like to build a set of the gauge wheels for the blade. Just can't decide if the effort to build the wheels would be worth it.... I don't use the blade that often.
   / Homemade edge tamers #12
I'm on my 2nd Winter season with my Chinese knock-off's -- did not realize the real deal was patented, but at roughly 1/2 the cost, they were certainly affordable. They work great, but they do not scrape the surface of my blacktop driveway very clean. I've got an inch, or more, of snow/ice melting, today. Been driving on it for a couple of weeks, now.
I love moving piles of snow with my FEL -- it's a blast! The County road turns 90-degrees, where my driveway meets it; the plow driver leaves me a 2-4 foot high pile of compressed snow/ice to clear, to get out of my driveway. The FEL clears it, easy-peasy, with the edge skis. In years past, I had to remove that wall with my walk-behind blower, slowly chewing it up, bit-by-bit. Now, the FEL just scoops it up, and lets me dump it in the ditch, easy and fast. Even though my edge skis don't scrape down to the pavement, they make such quick, easy work of moving massive amounts of snow, that I don't mind too much.
I buy 50# bags of Chicken Grit, and apply it liberally atop the surface ice. When the Sun comes out, the dark Chicken Grit absorbs heat and melts the ice almost like it was salt. No matter the temperature in tropical Southern Minnesota, the Chicken Grit bites into the snow and ice, when any rubber tires roll over it. I really like Chicken Grit better than sand, any day of the year. Cheers!
   / Homemade edge tamers #13
Never heard of chicken grit before, but I see Amazon sells it for about $20 for 50 pounds
   / Homemade edge tamers #14
I like the BOLT ON design detail of your fabrication.
I have the "real McKoy" edge tamers, and they are often bumped askew or even knocked off!
   / Homemade edge tamers #15
For the rear blade, I just turn it around backwards and it moves snow (or levels gravel) without moving it.
Of course, since I built / installed these, all we have gotten is a few dustings of snow! Haven't been able to try them on a decent amount of snow....
   / Homemade edge tamers #17
So far this winter has been a dud in our area. Good snow in the mountains, but not much in the plains. Hopefully that changes soon.
1974 John Deere 6030 Tractor (A55315)
1974 John Deere...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Portable Restroom (A54865)
Portable Restroom...
Sentry Safe (A54816)
2013 Ford F350 (A55973)
2013 Ford F350...
