Homemade Compressor
   / Homemade Compressor #11
Different question. I have friend who uses old propane tanks for compressor air storage. He finds old pumps, fixes them the hooks them to the propane tanks. I'm thinking of getting a tank to use as extended storage.
Is this ok to do this?
Wedge
   / Homemade Compressor #12
I use old propane tanks for air.
One thing to keep in mind...they used to contain propane. (Ya...I know...but some people don't think it through...)
Purge the he$$ out of them. I generally fill them up with water & dish soap a few times. The soap helps get rid of some, but never all, of the ethyl mercaptan residue in the tank. Then I leave them sitting in an unused area of the yard with the valves out & the openings pointing down for as long as I can.
   / Homemade Compressor #13
Going on what "Defective" stated, I have use old 40# propane tanks. To get rid of the stink, I paint them black and set out every day for a week in the hot summer sun. Then spray paint into the tank to seal the steel.
Seems to work and there is no stink when using the air.
jb
   / Homemade Compressor #14
I like the black paint & bake it idea...gonna hafta try that.
Do you ever have problems with the internal paint flaking off?
   / Homemade Compressor #15
I needed air on my two ton. I used an airconditioning unit off a toyota celica. It is a two piston unit with it's own crankcase. The tag on it is tested to 425lbs. With the electric clutch, it is nice to put a switch on the dash so it won't fire up unless I need it. I used a 5 gallon propane tank for storage and put an electric popoff switch that works at 125lbs. Be sure to put an emergency popoff that is preset incase of a switch failure. Wouldn't want a bomb to go off.
   / Homemade Compressor #16
How big is the compressor off the Celica?
I've always run York compressors on my trucks but I drive a VW van these days & there aint quite so much room in there.
   / Homemade Compressor #18
cool!
I bet it'd fit. Guess I'm gonna hafta make a trip to the wreckers & see what they have on hand.
Then I get to invent a bracket...then figure out a belt...then mount a tank...then run plumbing...FUN!
   / Homemade Compressor #19
I remember people used to modify the old air-cooled VW engines, using two cylinders to run, and two to compress, IIRC. There may have even been a kit. That would make a pretty cheap 20hp or so compressor.
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
2020 DRAGON ESP...
