Homemade Cab?
/ Homemade Cab? #11
Bed frame side rails will give you plenty of strength if you need some cheap steel. People always have these laying around. You can pick up a sheet of steel for the roof. Flat stock from HD or Lowes will sufice to make your door. Hinges are easy to get. Try to find a set of lift off style so you can remove the door easily. All you need now is the plastic for the windshield and 4 sides.
/ Homemade Cab? #12
Thanks Brent,
I could not figure out how to do that.
Tom, To bad you did not holler a mounth ago, the cab was for sale and got no feed back so I gave it to the guy that bought my tractor
/ Homemade Cab? #13
Has anyone ever built his own tractor cab? It's getting mighty cold out there in the tractor seat, but I don't really
What helped me--
Once I welded up my frame I went to a sheet metal shop and had them cut pannels from galvanized sheet stock for roof and sides which I then fasten to the square tubing frame with HD sheet metal screws. (cheating)
For the roof I built in rain gutters on the sides and over extender the front and rear by about 3" to keep rain from dripping down over the windows.
For windows I went to a scrap yard and obtained old school bus windows complete with the rubber trim and simply cut out the outline with my jig saw. That worked great.
For the rear window I installed hinges at the top to allow opening upwards and to easily remouve in the summer,
Old school busses also have heaters under some of the back seats that are just right to heat the tractor.
They are about 6"X6" and 4" thick.
I modified mine by installing a 4"x4" computer muffin fan to push the hot air.
Plumbing was accomplished using 1/2" standard copper pipe and rad hose between the cab and the motor.
Experimentation found that installing the heater at top right front section of the cab space, pointing downwards was best.
Because of the front and rear roof overhangs I rarely, if ever, use the wipers, even when snow blowing.
The school bus windows are large enough that they cover almost 80% of the pannels giving me great visibility.(plus they are safety glass and cheap!)
/ Homemade Cab?
PILOON - Lots of good help - thanks. I never would have thought of school bus windows. If they are like the ones I spent many years looking through, the top half slides up and down for ventilation. Great idea.
DDT - Sorry I missed out on your cab. It was a goody.
Tom
/ Homemade Cab? #16
</font><font color="blue" class="small">( Has anyone ever built his own tractor cab? It's getting mighty cold out there in the tractor seat, but I don't really
What helped me--
The school bus windows are large enough that they cover almost 80% of the pannels giving me great visibility.(plus they are safety glass and cheap!) )</font>
Photos would be great! Do you have any you could post? G
/ Homemade Cab? #17
OK, This will be first time I try images here,
this is the overall view
/ Homemade Cab? #18
Wiew of the windshield using school bus window that is mounted on a sheet of 16g galvanized metal and attached to the 1.5 X 1.5 sq tubing frame.
/ Homemade Cab? #19
View of rear window, again on galvanized sheet stock, but here you'll note that I had flanges formed on sides and bottom and that the top is attached with 2 hinges to allow ventilation on hot (rare up here) days.
/ Homemade Cab? #20
This pic showes how the frame sits on the tractor (MT189D) and relationship of windows etc.
The entry door is made up using bed side rails and hinged at front with a simple lever latch type affair to keep closed.
Bothe the door and the opposite side pannel is that 'convertable car top' plastic material that is attached using 1/2 round alu and sheet metal screws every ft or so.
Note how I trimmed some 1" MDF stock to fill in gaps around the fenders.
2017 Peterbilt 320 T/A E-Z Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Peterbilt 320...
AGT Industrial M-DGR (A60463)
AGT Industrial...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2024 JCB 35Z-1 (A60462)
2024 JCB 35Z-1...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
