Homemade 3pt Sod Cutter
   / Homemade 3pt Sod Cutter #1
snowmansimon
Kubota BX1860
Built a sod cutter to transfer sod into my fenced yard where the dogs run. I will then re grow the lawn outside the fence. I built this with material around the garage, other then the two $10 bearings. My 5 front weights fit on the back to keep some down pressure (3 weights pictured). The roller keeps the blade from going to deep. The blade is also adjustable in half inch increments. I set it up to be offset so the tractor runs on the grass. If it was centered half the tractor would run on the dirt and be slightly tipped. I suppose I could have adjusted 3pt to level the implement.
   / Homemade 3pt Sod Cutter #2
Welcome to TBN snowmanS. That's a pretty unique tool. Looks like it does just what you want :thumbsup: Very nice build.
gg
   / Homemade 3pt Sod Cutter #3
I like that!
When I was young I worked on the back of a sod harvester.
Looks great.
1304 (A58374)
1304 (A58374)
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
PALLET OF MISC PLYWOOD (A58374)
PALLET OF MISC...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A58018)
2006 INTERNATIONAL...
