snowmansimon
- Joined
- Jan 20, 2019
- Messages
- 8
- Tractor
- Kubota BX1860
Built a sod cutter to transfer sod into my fenced yard where the dogs run. I will then re grow the lawn outside the fence. I built this with material around the garage, other then the two $10 bearings. My 5 front weights fit on the back to keep some down pressure (3 weights pictured). The roller keeps the blade from going to deep. The blade is also adjustable in half inch increments. I set it up to be offset so the tractor runs on the grass. If it was centered half the tractor would run on the dirt and be slightly tipped. I suppose I could have adjusted 3pt to level the implement.
