Homelite 240 chainsaw
   / Homelite 240 chainsaw #11
LD1,
Everything you state is correct.
You are assuming:
1.-- that everyone inquiring has a chain on their saw and can correctly follow the process quoted. How does a casual user determine gauge without the proper tool??
Stated in my previous post. It is usually stamped right on thebar
2.--that the user is located near a supply house that can provide the proper chain I made no such assumption. I am just giving the 3 peices information required to properly size a chain.
3.--that it is worth the effort or just make a phone call had have it delivered
I live in a rural area and recently when through the process--drove the 30 miles to town. Saw shop was closed and the big box stores and hardware stores didn't stock the chain. Next option was to drive 200 miles round trip to the big city of Albuquerque. That chain would have cost me 5 hours of driving and $70 in fuel---go figure...
Call Amazon and have 2 chains delivered for $34.00
You however are assuming:
1. That the bar is 18", but it could be a 16" or a 14" or a 20". Only the OP can answer that.
2. That the bar has never been changed and that the origional .050 guage bar is still on the saw.
3. That the op lives in a rural area with no saw shops around.
I aso live in a rural area. We have pleanty of saw shops around. Most have 250' rolls of chain of all types and sizes and will assemble the correct length on the spot. And it is usually cheaper (at least in my case) than buying online. The place I usually go is a stihl dealer and he charges me $0.90 per inch of bar for sthil chain (which is regarded as the best). That would make 2 18" chains run $32.40 plus tax. I would rather do that, have better quality chain, and keep the business local.
An back to the main topic, I was trying to point out that you DONT need part numbers. If you know the # of DL's, guage, and pitch, then ANY chain that matches those 3 will fit your saw.
I have SEVERAL saws, I have never used a chain part #. I wouldn't even be able to tell you part #'s of the chains on my saws now. But I can tell you the pitch, DL count, and guage of all of them.
But to each his own. If you want to order/buy chain with part #'s, so be it. There is more than one way to skin a cat.
   / Homelite 240 chainsaw #12
I have a 240 sitting around here somewhere. I may even have a few new chains for an 18" bar. My sprocket went and you can't change just the sprocket so I just put the saw in the corner (next to the others). It sounds like you have the information you need but if not I see if I have a box with the information on it.
   / Homelite 240 chainsaw #13
crazyal,
you can't just change the sprocket because the 240 doesn't have the drum/rim set-up, you can however replace the 3/8 low profile drum/spur sprocket set-up you have on the saw; oregon still sells them & if I recall it is around $16 for the part. Another way to go would be to contact 'Lil red barn in Harrisonbug Va (they also sell on ebay, just do a seller search); they used to sell the clutch/sprocket, bar & chain set-up to swap the 240 over to a .325 pitch chain which is a more readily available chain size than the 3/8 low profile.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2018 Freightliner M2 106 Medium Duty AWD Altec AA55 56ft Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3 Ton Crane Service Truck (A55973)
2017 Ford F-550...
