Homebrew steel tires and wheels?
   / Homebrew steel tires and wheels? #1
The Haymaker
Benton, Maine
2008 T2220
I just spent a bunch of time working in the Finger Lakes Region of NY. What is up with this? Other than no flats, that is!:D I saw them everywhere, with all brands of farmers using them. All sizes and shapes, even saw a set on a small yard tractor.
The owner of a hardware store in Himrod said it cost him 1900 to make a set for his Farmall H.
   / Homebrew steel tires and wheels? #2
They must be for high speed cornering.
They sure can't be for improved ride quality.
Maybe thats how you put low profile tires on a tractor to match the ones on your car.
If you look carefully, they do have some give. About an inch. Very hard on pavement where they cross the road, but no worse than all the horsehoes moving around. Make a funky noise on gravel too!
   / Homebrew steel tires and wheels? #5
Will be interested in learning more about them.
For sure, not impressed with their looks.
But maybe they would be functional in a quarry or very rocky surface.
Anyone know more about the why behind them?
   / Homebrew steel tires and wheels? #6
Bet they wear well too,not many flats:DDave
   / Homebrew steel tires and wheels? #7
Don't think it's related to the wheels you posted HM, but interesting non-the-less.
Munson: Mennonites' steel-cleated tractors pit road maintenance vs. religion | desmoinesregister.com | The Des Moines Register
Rubber tires offer a faster, smoother ride down the highway than the cumbersome cleats. So Mennonites fear the use of tires would entice families to take more trips into town on their tractors. It could represent an irreversible step down the slippery slope that leads to the next generation abandoning horses and buggies for cars. Close-knit Mennonite communities could be shattered.
section
bilde
bilde
When I asked the owner of another local agri-shop, his immediate answer was "You never get a flat". If working the fields, which 90% of that area is, I'm sure they work very well.
E
   / Homebrew steel tires and wheels? #9
I'd buy into the mennonite theory, but not the "never get a flat" reason :D
Just don't get that many flats in fields. IMO :)
   / Homebrew steel tires and wheels? #10
I seem to remember something similar here on the forum years ago. As I recall they were used because of locus thorns causing flats at an alarming rate. Any idea if that area has much locus?
MarkV
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
1989 Freightliner Cabover FLA086 (A53472)
1989 Freightliner...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
