Home made Heaters?
/ Home made Heaters? #1
Dataway
Greenfield TN
Ford 1715, BX2200
Anybody made their own cab heaters?
If I should just use the search engine...tell me and delete this thread :)
JohnnyB
/ Home made Heaters? #2
I tried to make one for a skid steer cab. I used a small heater core from the parts store and built a heater box around it. The core gets good and hot but the fan I used does not put out enough air. I will need to rework it so that I can install a better fan then it should work just fine.
Rob
/ Home made Heaters? #3
One can but heater cores and fan combinations but I would be scrounging through the car wreckers lots to see if they had had something that would work.:D :D
/ Home made Heaters? #4
I am planning on building one as well. My plan is to use a computer fan (or two) since they:
- Are cheap
- Move a good amount of air
- Don't draw much juice
Check out this link or do a search on computer cooling systems as they have radiator cores that are all set up to accept these fans (they are made to cool high power CPUs)
Radiators | Shrouds | Page 1 | Sort By: Highest Rating - FrozenCPU.com
Thanks for the ideas.... I've got a small metal fabrication shop...should be able to come up with something similar.
JohnnyB
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
