Home made Heaters?
/ Home made Heaters? #1
Dataway
Greenfield TN
Ford 1715, BX2200
Anybody made their own cab heaters?
If I should just use the search engine...tell me and delete this thread :)
JohnnyB
/ Home made Heaters? #2
I tried to make one for a skid steer cab. I used a small heater core from the parts store and built a heater box around it. The core gets good and hot but the fan I used does not put out enough air. I will need to rework it so that I can install a better fan then it should work just fine.
Rob
/ Home made Heaters? #3
One can but heater cores and fan combinations but I would be scrounging through the car wreckers lots to see if they had had something that would work.:D :D
/ Home made Heaters? #4
I am planning on building one as well. My plan is to use a computer fan (or two) since they:
- Are cheap
- Move a good amount of air
- Don't draw much juice
Check out this link or do a search on computer cooling systems as they have radiator cores that are all set up to accept these fans (they are made to cool high power CPUs)
Radiators | Shrouds | Page 1 | Sort By: Highest Rating - FrozenCPU.com
Thanks for the ideas.... I've got a small metal fabrication shop...should be able to come up with something similar.
JohnnyB
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A65563)
2004 MCI D4500...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2007 Mack CV713 Granite Truck, VIN # 1M2AG11C37M043941 (A65563)
2007 Mack CV713...
