Home Made Concrete Mixer Pictures
   / Home Made Concrete Mixer Pictures #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
Here are some pictures of the Concrete Mixer I built
using a 55 gallon polyethylene drum.
Here is the mixer itself. You can also see the sand/gravel mix
that I get from down at the river to make concrete with.
Here is a front view of the mixer. The battery you see hanging there
is a counterweight to help me dump the drum when it is full.
Here is a close up view of one of the paddles inside the drum.
Here is part of the drive system for the mixer.
A 1725 RPM 1.5HP motor drives a 50:1 RA gearbox via a LoveJoy coupler
and the gearbox has a 3 inch sprocket on it and drives a 4.5 inch
sprocket on the drum shaft using a #50 roller chain.
Gives me a final drum speed of about 23 RPM.
Here are some of the paving block molds I have poured.
They are 12inches by 12inches x 3.5 inches thick.
And here is what I have been doing with them so far.
Making a walkway from my parent's house front steps to their driveway.
So far this thing works great.
Pooh Bear
   / Home Made Concrete Mixer Pictures #2
are those off the shelf replacement paddles for a simular type mixer?
   / Home Made Concrete Mixer Pictures #3
That's a very ingenious and interesting setup you have there. How much do you estimate you can make at one time?
The paddles were cut from a big piece of flat metal.
They are bolted in place using L brackets from the hardware store.
And they are not angled. Just straight with the drum.
I mix about 1.5 cubic feet per batch.
20 shovels of sand/gravel and 5 shovels of concrete.
Just enough so that one batch makes 4 paving blocks.
Any more than that and it gets too heavy to dump.
If I was strong enough I could probably mix 3 cf per batch.
Max capacity is just over 4 cubic feet.
Those mixers you see at Lowes and Home Depot and Tractor Supply,
they have 3.5 CF drums but will only mix about 1.5 CF of concrete.
A CF of concrete is about 150# and it says on the box "will mix up to 220#."
So don't be fooled by those 3.5 CF drums.
My mixer is not very portable. Unless you have a forklift.
The base of it is made out of old pallets.
I can use the tractor to drag it around the yard by a chain.
I figured for just making paving blocks it can just sit in one place.
Pooh Bear
   / Home Made Concrete Mixer Pictures #5
Afternoon Pooh Bear,
Very ingenious ! And budget oriented also ! ;) Thanks.
   / Home Made Concrete Mixer Pictures #6
Holy smokes that's a great idea! I've been thinking about some way to mix potting soil easily...I think I just found it!
   / Home Made Concrete Mixer Pictures #7
Pooh_Bear said:
Pooh Bear
Neat! Step aside MacGyver, Pooh Bear's taking over ! :p
What could you make with a pack of bubble gum, a soda can and the spring from a ballpoint pen ?
   / Home Made Concrete Mixer Pictures #8
That's a great setup you engineered there Pooh. Impressed with you utilization of resources.....:) You are a thinking man!
   / Home Made Concrete Mixer Pictures #9
DMF for potting soil.
Get your self a snap ring drumb and put the matieral in it, then lock the lid, lay it on its side and push it around for a few minutes till it is mixed. I mean push it with your tractor.
   / Home Made Concrete Mixer Pictures #10
Pooh, I really dig the battery counterweight! I think rednecks just got themselves a new king!:D:D:D Very ingenious.
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
STORAGE FEES (A52576)
