Home Made Concrete Mixer Pictures
   / Home Made Concrete Mixer Pictures #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
Here are some pictures of the Concrete Mixer I built
using a 55 gallon polyethylene drum.
Here is the mixer itself. You can also see the sand/gravel mix
that I get from down at the river to make concrete with.
Here is a front view of the mixer. The battery you see hanging there
is a counterweight to help me dump the drum when it is full.
Here is a close up view of one of the paddles inside the drum.
Here is part of the drive system for the mixer.
A 1725 RPM 1.5HP motor drives a 50:1 RA gearbox via a LoveJoy coupler
and the gearbox has a 3 inch sprocket on it and drives a 4.5 inch
sprocket on the drum shaft using a #50 roller chain.
Gives me a final drum speed of about 23 RPM.
Here are some of the paving block molds I have poured.
They are 12inches by 12inches x 3.5 inches thick.
And here is what I have been doing with them so far.
Making a walkway from my parent's house front steps to their driveway.
So far this thing works great.
Pooh Bear
   / Home Made Concrete Mixer Pictures #2
are those off the shelf replacement paddles for a simular type mixer?
   / Home Made Concrete Mixer Pictures #3
That's a very ingenious and interesting setup you have there. How much do you estimate you can make at one time?
The paddles were cut from a big piece of flat metal.
They are bolted in place using L brackets from the hardware store.
And they are not angled. Just straight with the drum.
I mix about 1.5 cubic feet per batch.
20 shovels of sand/gravel and 5 shovels of concrete.
Just enough so that one batch makes 4 paving blocks.
Any more than that and it gets too heavy to dump.
If I was strong enough I could probably mix 3 cf per batch.
Max capacity is just over 4 cubic feet.
Those mixers you see at Lowes and Home Depot and Tractor Supply,
they have 3.5 CF drums but will only mix about 1.5 CF of concrete.
A CF of concrete is about 150# and it says on the box "will mix up to 220#."
So don't be fooled by those 3.5 CF drums.
My mixer is not very portable. Unless you have a forklift.
The base of it is made out of old pallets.
I can use the tractor to drag it around the yard by a chain.
I figured for just making paving blocks it can just sit in one place.
Pooh Bear
   / Home Made Concrete Mixer Pictures #5
Afternoon Pooh Bear,
Very ingenious ! And budget oriented also ! ;) Thanks.
   / Home Made Concrete Mixer Pictures #6
Holy smokes that's a great idea! I've been thinking about some way to mix potting soil easily...I think I just found it!
   / Home Made Concrete Mixer Pictures #7
Pooh_Bear said:
Pooh Bear
Neat! Step aside MacGyver, Pooh Bear's taking over ! :p
What could you make with a pack of bubble gum, a soda can and the spring from a ballpoint pen ?
   / Home Made Concrete Mixer Pictures #8
That's a great setup you engineered there Pooh. Impressed with you utilization of resources.....:) You are a thinking man!
   / Home Made Concrete Mixer Pictures #9
DMF for potting soil.
Get your self a snap ring drumb and put the matieral in it, then lock the lid, lay it on its side and push it around for a few minutes till it is mixed. I mean push it with your tractor.
   / Home Made Concrete Mixer Pictures #10
Pooh, I really dig the battery counterweight! I think rednecks just got themselves a new king!:D:D:D Very ingenious.
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
