Home Made Backhoe thumb
   / Home Made Backhoe thumb #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
Ive got a Bradco 3265 3 pt hitch Backhoe and made a "Thumb" for the bucket so that I can pick up heavy rocks, Logs, and any other stuff that needs to be picked up and moved.
The Backhoe has a 12" bucket & I have an 8" bucket for trenching. I used the 8" bucket for the Thumb and mounted it to the Backhoe with a couple of leaf springs salvaged from a 1959 cadillac and some 3-9/16" square "U" bolts. My neighbor helped me to mill out some metal for the mounts. I did not drill or weld the backhoe. The mounts can stay in place during normal operation. I can remove the bucket Thumb by pulling two 1" pins. I tried it out on a heavy rock and it works great.
   / Home Made Backhoe thumb #2
That looks like a GREAT idea!!! Very ingenious! I can't quite make out your attachment hardware, could you kindly post a closeup?
Cheers!
   / Home Made Backhoe thumb #3
Very interesting. I would like to see more pictures how it looks folded back out of the way in the non-working position.
Welcome to TBN!
   / Home Made Backhoe thumb #4
Great idea, GuglioLS!
I have a 10" bucket just sitting there when I have my 16" on the backhoe... /forums/images/graemlins/shocked.gif
Thanks for a great idea and most important, Welcome to TBN! ( I see this was your first post /forums/images/graemlins/cool.gif )
Please do post more detailed photos if you can.
I used a couple of leaf springs from an old car it had 1" diameter ends. Perfect for mounting the bucket that had 1" clevis pin mounting holes.
I have a question - How do I post multiple pictures to my posting?
Here is another picture.
This one is of the Mount attached to the Backhoe.
The Thumb bucket is removed.
How do I attach multiple pictures? I am new to this site and don't have it quite figured out yet. Please forgive me if I am doing this wrong.
   / Home Made Backhoe thumb #7
You're doing a perfect job of posting multiple pictures. The correct method is to post each one as a reply to your initial post.
Backhoe Thumb mount closeup 1
Backhoe Thumb The "Big Picture" (Whole thing) With some of my land and home in the background.
   / Home Made Backhoe thumb #10
Thanks for the add'l. pix! Very cool job. Beautiful property too !
Cheers!
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
