Home Depot Service Trailer???
   / Home Depot Service Trailer??? #5
CompactTractorFan said:
I personally think the axle is too light. I'd rather see at least a 5200 or 6000 lb axle under it. At 3000 lbs there isn't much room for stuff.
Brian
Brian
Yes, when I first saw it I thought that...
   / Home Depot Service Trailer??? #7
Seems like a reasonable idea, just seems like you could do something similar for less money. Also seems to me, having been on job sites for many years, that trailers often have more problems finding a place on the site. That means more work to get your tools where you need them to be because you park farther away. Tools become heavier the older your get has been my experience.
Of course if your work is not restricted by site size this may be the perfect thing. I use a heavy duty van so I can carry everything and get as close as possible to the work. If that were not a requirement I might well drive something else.
MarkV
   / Home Depot Service Trailer??? #8
MarkV
I would like the trailer but I hate Home Depot.
Any idea of where to buy one used ?
SW
   / Home Depot Service Trailer??? #9
If you don't want to build a trailer. There should be a trailer dealer not 2 far away. You will get a lot more trailer for about the same amount of money. When I got my 18' at first I looked at used, very often the used trailer cost more than the new one that I bought.
   / Home Depot Service Trailer??? #10
I would think that an enclosed trailer set up with racks/boxes etc. to fit the exact need would be a better option. I find compartments restrictive due to size limitations. Also, one door to lock instead of many small ones. That's my two cents.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
