home cooling questions
/ home cooling questions #21
Granted you have an A frame, but in our ranch design about the same size. I removed the light fixture in the hall way which is centrally located and put in an over the rafter house fan. I put it on hinges so I could lift it in the winter and replace the plywood and insulation. Then used the foam rubber seal that they use on truck caps to body. This went on the fan base to keep vibration noise to a minimum, and I tighten it down to the floor with small turn buckles. What I really like though is I was able to replace the light switch with a thermostat, so it will shut off at night once it hits the optimum temp.
One thing worth noting is I pull the switch cord on the fan during the winter to ensure its is off. We burn a pellet stove in the winter. If we ever had a house fire the fan would kick on because of the thermostat.
As for the AC unit, we could not find a suitable place in the house where it would be most efficient; IE...out of direct sun or it would be too noisy in the living room, so I cut a hole in the wall. Sounds extreme, but it looks very professional, and it’s hidden behind a large arbiverite so you cannot see it from outside very well. I also got the manufactures cover for the winter. We use this during extreme heat, for me that’s anything over 80 with a breeze. /forums/images/graemlins/grin.gif
Hope this gives ya some ideas
/ home cooling questions #22
/ home cooling questions #23
I see that you are in Pennsylvania, it isn't that hot for that many months is it? Instead of fixing the problem consider going around the problem. Perhaps get some furniture that will provide comfortable sleeping and sleep in another room that you can put in a casement air conditioner. Short term your wife is cooler. You can always sell a used air conditioner if you put in whole house a/c in a year or two.
A year from now your budget may change and you can put in the correct whole house solution.
/ home cooling questions #24
/ home cooling questions #25
<font color="blue">"...two years ago for a mini-split for the greatroom and our bedroom..." </font>
Forgeblast, Have you received up to date quote for a minisplit just for the bedroom?
I just check out the neighbors minisplit on a old farm house and he has and one evaporator which cools about half of his house. It is a lot quieter than a window/wall AC. I'm still waiting on my estimate.
/ home cooling questions #26
/ home cooling questions #27
</font><font color="blue" class="small">( Hi we have a 1600sf a-frame with casement windows. we have a whole house fan, a great room with fans and our bedroom is upstairs (no windows only sky lights). Needless to say when it gets hot (today 90) my wife heats up and i hear it.
Portable ac does not work, tried it. i am not sure if i want to rip a window out just to put in a casemnt ac. I looked at the installiation and i have to rip all of the window hardware out to fit it in.
we had a quote two years ago for a mini-split for the greatroom and our bedroom, and it came to 5k. Thats more then we can spend right now.
Any suggestions?
Thanks in advance
forgeblast )</font>
Sleep downstairs during the warm weather.
Bob
/ home cooling questions #28
Any suggestions?
Thanks in advance
forgeblast )</font>
Bob
/ home cooling questions #29
You may think this is goofy, but when I had a similar problem out here in CA, I set up the lawn sprinkler so that it sprinkled the sunlit side of the roof. It was a move born of desperation since I had an afternoon party going and about 100 people roasting in the house.
Anyway, that was the zero-cost trial. It worked very, very well, but used too much water for my liking.
So, after I proved that the concept worked I went to a plumbing shop and got a handful of mister heads (puts out a fine water mist). Then I got about 40' of white PVC pipe and made up a rig that sat on the house with a mist head about every 10' on the roof. Attached a garden hose and it cooled the house better than AC. I had to adjust the water flow every hour or two, so that there was just enough to get a trickle of runoff, but not very much.
You want to set up the mist heads so that the entire sunlit side of the roof is covered with the mist.
The proof test was free, the final installation was under $50 and it worked like a champ for years. The we moved to a tree-shaded house and there was no need for a mist cooler.
/ home cooling questions #30
I emailed the guy about the mini split system again, the inital estimate about a year ago was 5k, with two systems. one that would cool our bedroom, and one that would cool our great room. I asked him if we could do half of the system, and then when we had enough come back and do the other half. hes a real nice guy and was working with us last time to get the best system at the best price. after seeing his estimate vs sears (8-9k) i was going with him hands down.
Your right the cooling season is not that long here, but on some days its really bad. The basement is not finished, so ther really is no room to stay down there. plus the dogs are down there. As for cutting a hole in the bedroom wall, our walls slope. And the ones that dont have the dressers against them. There is just no where to put them. The weather broke a bit yesterday, had a bad thunder/lighting storm, dumped a ton of water but broke the humidity and heat.
thanks for the suggestions all.
we havent melted yet, so i guess we can get through this week. lol
/ home cooling questions #33
</font><font color="blue" class="small">( our walls slope )</font>
That's why God invented dormers. /forums/images/graemlins/laugh.gif
/ home cooling questions #34
/ home cooling questions #35
Would it help to replace one of the sky lights with one that can open to vent off some of the heat located in that high spot of the house? I think they run in the $500 range.
Some friends with sky lights in an attic conversion made some inserts of foam insulation board for their sky lights to fight the summer heat. Seems to have helped.
MarkV
/ home cooling questions #36
MarkV
Sorry forgot to say they are the ones that open up. and yes that helps a ton. i think we are going to get blackout curtains for them. i like the board idea too.
thanks
thanks
/ home cooling questions #39
For the upstairs in the barn - kids play room and quests bed room - I bought split unit on ebay. Installed it myself and the plumber - neighbour - just connected copper lines and charged it for $200. Now the area is 40 feet by 16 feet and this little thing can cool it down even in the hottest day (the roof has 6 inch fiberglass insulation) and heat it up even if the temp outside is only 40 F. Well spent money - and it wasn't that dificult to put it in. Just little bit of wiring and soft copper line routing.
/ home cooling questions #40
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
39' Double Track Aluminum Gate (A64912)
39' Double Track...
