Home building with a tractor
   / Home building with a tractor #11
I have a small JD 4100 with FEL that was used during the construction of our house.
Even though I contracted out all the main digging for the basement and the water line, the 4100 got used a LOT!
Its not clear we saved a heck of a lot of money, but it was very convenient to have the machine there, so it saved a lot of time. I never had to call anybody or run to the rental place for a bobcat just to move a pile of rocks, or load trash, or whatever - I just hopped on the 4100 and got the work done.
Some of the uses:
- Place drainage gravel around foundation.
- Backfill around foundation. This was a bigger job than expected - a larger machione would have been better, but we just plugged away on the 4100 and eventually got it all done.
- Placement and rough leveling of sand in foundation for under basement floor slab.
- Removal of left-over rocks from excavation.
- Emtying the silt fences after large rains.
- Moving various materials, appliances, and tools around as required using forks. Not big enough for a full pallet of stone, or a unit of lumber, but restacking stuff in-place to make smaller loads is still a lot less work than a wheel-barrow.
- Snow removal
- Weed control (mowing)
- Spreading rock for temporary driveway.
- Placement of sand under garage floor slabs.
- Sprinkler system install (using sub-soiler and trencher attachment).
- rough grading of some portions of the yard (some grading was contracted out).
- loading of scrap and debris into dumpsters or the utility trailer for removal. We removed at least 5 30-yard dumpsters and another half dozen trips in a 3500lb trailer.
- removal of mud tracked onto public street using sweeper attachment.
- removal of a retaining wall.
- demolition of an old deck off the old house.
- loading of demolition debris from removal of old house.
- removal of portions of an old asphalt driveway that were in the way (bulk of driveway removed by contractor).
- cleanup of sand pile the stucco crew left behind.
- placement of landscape rock
- supplemental backfilling some settled areas where water-line was dug.
- back-filling behind new retaining wall.
- removal of an old basketball pole (and attached concrete).
- pulling other stuck equipment out of the mud or off of the ice, including a 40' high snorkel-lift and a full-size semi truck (empty).
- moving trailers around (two boats and a utility trailer, they were always in the way).
- moving tractor attachments around (they were also always in the way).
- raking of yard prior to sod.
- tilling of yard prior to sod.
- cutting grass.
Now that I am moved in, I plan to sell some of the attachments, but I am torn on the FEL. On one hand, I don't anticipate having a lot of dirt to move around anymore. On the other hand, if I ever do need to dig or move stuff (especially using the forks), it comes in darn handy.
The landscape rake, back-blade, and sub-soiler are all going to be sold.
The trencher and tiller were borrowed and have been returned.
The front blade, sweeper, and mower I plan to keep - the 4100 is small enough to make a very HD lawn tractor.
The front-mount snowblower I wish was a rear-mount, so I plan to trade it for a 3-pt version.
- Rick
   / Home building with a tractor #12
Brian, I'll second your stick in the mud attitude. The tractor will be indispensible for all the small chores but for grading, septic tank, leach field etc., I would just say that you will be way ahead to hire a professional get it done fast, correctly and save the wear and tear. There will be many things a compact with a loader will do for you during the building process from moving gravel, dirt, trash etc. to help justify it's need, just not the big stuff. With a construction loan in the mix, time will be of the essence.
   / Home building with a tractor #13
Well I guess I am a stick in the mud of a different sort...
If I only had had a real tractor/backhoe when I started building back in 1980!
Now maybe I would still have been smart enough to get the tracked loader in to dig the foundation...but I could have done it with my B2910 today, as it is in a hillside and there were not any major rocks to deal with...
There are so many little things a tractor w/loader could be so helpful with...
The more you do yourself the more helpful it will be.
But you do have to realize the limitations.
Still...I wish I had had a tractor twenty years sooner.
If you can afford it go for it. But don't expect for it to pay for itself in dollars. Your back will thank you but it may be difficult to prove the tractor was worth it dollar wise.
But it will be worth it, and the more you do yourself the more you will see the worth of it.
The more you contract out, the less value the tractor will have I think.
I did 99 percent myself so a tractor would have had a lot of worth...
   / Home building with a tractor #14
I am in the process of building a house and have 3 machines. A large CUT 43hp, a Utility tractor 75hp and a 44,000 lb excavator. Where I live the 75hp TN with an 11 foot backhoe would take a lot of time to dig a foundation. The excavator makes quick work of it and the large stones as well as stripping loam so that a FEL can move it. As far as using a trencher for water lines, yes in sun country, but not around here where you need to go down below frost level.
Andy
   / Home building with a tractor #15
All I can say is that I wish I had my Kubota L4310 when we were building the house. We did about 50% of the house building. Had an excavator do the digging, etc. Still - I would have saved many, many hard hours by having a tractor on site.
Rich
   / Home building with a tractor #16
Rich, that is so true. I think how often we used a tractor/loader for cleaining up to bringing heavy material right to the spot it will get used. It will get used considerably.
   / Home building with a tractor #17
When I put an addition on my house I rented a slew of different machines to get the work done (small excavators,bobcats, etc...) and kept thinking I would be better off buying a CUT. When I went to dealer to see them (on the side of the big boys) I thought the thing was not much bigger then my lawn tractor and decided against buying at that time, a few more bad experiences renting machines and I am now the proud owner of a BX23. I love the tractor but I recently spent the better part of a weekend excavating for a 12'x20' foundation that I could have done in a few hours with an excavator. I now have to increase my leaching fields and the design that I worked out with my local Health Dept. calls for me to ig a 6'w x 100' long trench that I will definately be renting an excavator to do, I will use my BX23 to backfill. My wife gives me plenty of grief about having to rent another machine to do some of the work but I can't get her to understand that no 1 machine will do it all
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
Informational Lot - Shipping (A55314)
Informational Lot...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
