homade box blade
/ homade box blade #12
I think he just bought a used one and repainted it. :laughing: Man, that looks better than factory! Awesome job on it, workmanship looks very professional. Congrats!
The only comment I have is on most BB's I've seen (including the one I have now) the blade is set at about 50 or 60 deg angle (haven't actually measured it). Why did you go with that 70deg angle? Seems like it will have less tendency to "dig deeper", but I am sure it will still move a lot of dirt around.
/ homade box blade #13
who needs a plasma cutter anyways....you sure dont! great job!!!
/ homade box blade #14
Yes, I do have diff lock. That helps to a point. When the bb gets full we start spinning our wheels. How do you preload tractor tires anyway and what do you put in them? My dads ole international harvestor has preloaded tires. They were loaded years ago, and the liquid that comes out is clear.
It was possibly chloride, I think they used to use anti freeze too. I have sugar beet juice in mine, just the rear tires. I dont know what other folks are using. The local tire shop filled them for me, was gonna do it myself but the price was right and if you dont get enough in there, you will here it sloshing around. :ashamed: It definetly made a noticable difference. Let me know what you fill yours with?
/ homade box blade
Thanks to all for the comments on my home project. I am glad to have a web site to share my projects with all of you. Someone asked about the angle of the cutter blade, I looked at several and looked at a friend of mines box blade and his was set at 65 degrees. I set it at 70 degrees hopeing to not have so much an aggresive cutter. From using it for several hours it does me a fine job, mabe a little bit too good, a full load of dirt and I have to start rasing it up a little bit cause our wheels start to spin. I hope preloading the tires will help out with that. Thanks to you all again.
/ homade box blade #16
Welcome Zeus. You sure know how to use a torch, and your BB turned out quite nice.
That's the first thing I noticed, how straight a line cutting free hand with an OA torch and that thick plate looks 1"
I use my torch less now that I have all kinds of saws, but at one time I used the torch for everything, but I never got such nice cuts.
Heaver is better than lighter with the box blade, I was using mine today to clean up a drain swale. I have a HTL and even trying all kinds of angles I could not get it to dig in under some grass/turf with out putting some weight on it. I didn't have the rippers on as I did not want to go to deep.
JB
/ homade box blade #17
Holy cow man. Is that a regular oxi-ac torch setup? If it is then you must be a machine. That is the best looking cutting with that apparatus that I have ever seen. Is there some sort of a ... something that you can share about that?
Oh yes it is a nice box blade too.
/ homade box blade
Easygo, bout the only thing I can tell you about torch cutting is practice, practice and practice again. I am not very old, 33, (atleast by my standards) I work in the industrial fabrication business, and have spent many many hours behind one of thoes victor torches. I can try to make a video and post it on utube.
/ homade box blade #19
I was thinking maybe a straight edge but even then....
I know the torch is capable I have had moments that surprised me how fast you can move, but then a little hiccup and you loose it.
I've got a tip that allows you to rest it right on the surface and drag it along so that helps a little, but it's still hard to hold it steady.
JB
/ homade box blade #20
I went to a couple of web sites, and to my local TSC and looked at a few models, which look ok, but built a little bit on the light side.
Looks like you corrected that failing big time! Looking at the tractor you're powering it with, I wonder if it bucks like a stallion if you let the clutch out too quick with the BB up!:laughing::laughing: I have to add my compliments to the many already posted! Your steady hand with the torch is simply awesome! I have not done torch work for years but will be soon on my own project. I have to assume that getting the flame just right is key. :thumbsup:
iDrive TDS-2010H...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2005 Sterling Acterra Tender Truck (A61307)
2005 Sterling...
