Holy Caroni!!! Its here its here!!
   / Holy Caroni!!! Its here its here!! #1
hunt4570
Elite Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So my Gen-U-Wine 73 inch Caroni flail mower finally arrived today... and it doesn't work!! I'll get to that in a minute..
So I'm working about the place today trying to clean some stuff up, get some posts in the ground and get a dog fence up... beat myself up a bit and then the delivery guy calls, be there at 2 with the mower..WHOOHOO!! ITS HERE ITS HERE...
So to unload it I have to put it together first so I can chain it off the truck, the driver is real nice and says no problem, do what you need to do. So I get the top link part of the 3ph attached so I've a way to pick it up. off the truck it comes, set it down and hook it up to the tractor and off to the barn to finish up.
Get everything torqued down, fill the gear box, grease all the fittings (they've put holes in the covers to accommodate this now), go to install the PTO shaft and its about 2 inches too long (remember the it doesn't work thing above, this is why). Not a real big deal, I'll need to cut it down 5-6 inches. Really really wanted to do it today to see how it mows, but Iwas beat, had a vet appt for my dog and had to get cleaned up...so it will just have to wait till tomorrow.
Stay tuned, I'll let you know how it goes..
Heres proof!:D:cool:
   / Holy Caroni!!! Its here its here!! #3
Congrat's on the new piece of equipment! I am sure you will get good service out of it. Make some careful measurements, you don't want to cut the PTO shaft too short!!
   / Holy Caroni!!! Its here its here!! #4
Gee, looking at the photos, seeing the green plants, etc., I had to check to see when you posted- today!! How can that be? All I see when I look outside is snow and ice. Flail away.
   / Holy Caroni!!! Its here its here!! #6
I didn't need to shorten the drive shaft on my Caroni, but did on several other attachments. The procedure is simple as pi. My mower is a little over one year old and has been trouble-free. The only thing I don't like about it is -- it is not quick hitch compatible and far from it!
One of the main reasons I just moved here in December from colorado! Could not wait to get out of that nasty place! And I'm sure its all white now!:D
   / Holy Caroni!!! Its here its here!! #8
Very nice! A flail mower is on my short list of implements to add.
Ok,got the PTO shaft cut (excellent video on EA btw) dropped the feet on the sides and the rear roller so it cuts a bit high till I get used to it and to lessen the stuff I might hit till I get the place cleaned up a bit.
Did a little mowing just to see how it did, and I'll say at least for now I am pleased.. and I'll get better, still have to get used to the fact it sticks way out on that right side.
A couple more pics
I had to open up some fence to get into this "garden" field, only had a walk gate.. and an 8 foot high fence!
And here is after mowing, some of those larger trees I took a chainsaw to!
And put it to bed, then back to the task at hand, I've a fence to put up!
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
19009 (A48082)
19009 (A48082)
Ih 490 Disk (A50514)
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
