Holiday Smoking, YUM
   / Holiday Smoking, YUM #1
Dutch445
Elite Member
Upstate NY
JD X585
took me about 3 years, but I think I finally got this smoking thing
down.
We had a H.S. graduation party on Saturday so we served up some
food for about 80. The menu had mac/potato salad, cole slaw,
baked beans, sausage/peppers, hot dogs, pulled pork and brisket!
my G/F does the pork in a crock pot, and it is excellant. I do the
brisket in a smoker, and this time it was incredible. We smoked 3
full briskets, about 45lbs, but really only needed 1 for the party. Lots
of leftovers and some to take to other parties!
my process was different this time, using the brinkmann smoker,
I seasoned the meat with salt/pepper/paprika/garlic powder, and
a seasoning salt. then used Kingsford charcoal with Hickory, with a mix of
Hickory/Apple/Cherry wood for smoke flavor. Put the meat on for 6 hrs in the
smoke, then wrapped in HD alum foil and put back in smoker for another 5 hrs,
all running around 200 degrees give or take. Took the meat off, and put
in the fridge till the following day and just warmed in an oven to serving temp,
opened up the foil, and tried to cut it. It just melted. Had a great bark, good flavor,
and the most tender I could ever ask for. I literally had a
hard time slicing it because the knife wouldn't cut thru the bark before the
meat just shredded, but that's not a bad problem to have! Everybody loved it!
here's a couple pictures, of early and later in the smoker.
   / Holiday Smoking, YUM #2
down.
Looks sweet man, i have a hard time finding full brisket around here. I just did some butt and spare ribs the other week, still working on getting those $@*#% ribs right. Ive gone from moist and chewy to fall off the bone but dry. Going to try foiling differently. Not to be a nitpicker, "I literally had a
meat just shredded, but that's not a bad problem to have!". But that statement usually means you have overcooked your brisket. Acorrding to judging handbook recommendations, brisket meat should have slight elasticity yet pull apart under slight pressure. You want to avoid crumbling or shredding. Just pointing that out as everytime I do it, its a learning experience.. Makes it that much better the next time :licking:
   / Holiday Smoking, YUM #3
That looks terrific, Dutch. I did two dozen chicken breasts and a 4-lb bologna for the 4th. It was the first bologna I had ever smoked and it is terrific. I marinated the chicken breasts for 12 hours before smoking and cooked them 2-1/2 hours at 200 degrees. I kept the bologna in the smoker another 1/2 hour. I have a Masterbuilt electric smoker and it is extremely easy to use. The hardest job is cleanup.:)
   / Holiday Smoking, YUM #4
Yeah, and I'm gettin' old and lazy, I guess. The last brisket I bought was $1.78 a pound and I noticed them for $1.48 a pound at Walmart today, and didn't even buy one.:eek:
But all the Walmarts in this area have had some good sweet corn for $.15 an ear the last week or so, and we did buy several of those.
   / Holiday Smoking, YUM #5
Good brisket is hard to beat, but give me some of those roasting ears soaked in water shucks and all and then cooked over charcoal. Uhmmmmmm!!
Charlie
   / Holiday Smoking, YUM #6
Charlie
My wife showed me how to cook ears in the husk. Sure seems better that way.
   / Holiday Smoking, YUM #7
Looks good. I am going to smoke a full brisket this w/e. Last weekend it was a nice buffalo roast and the week before it was a boneless leg of lamb. I love my propane smoker. Started out with a Brinkman charcoal, and upgraded when it took 13 hrs to get a medium sized turkey done one Thanksgiving when it was cold and I couldn't get any heat.My next project is a smokehouse so I can cold smoke. I can't keep the heat low enough to do cheese in the propane. It will come in handy for hams, bacon and smoked sausage when we butcher too. I have been running my sausage through the neighbor's old smokehouse the last couple of years, and it is time to get one built on my place
meat just shredded, but that's not a bad problem to have!". But that statement usually means you have overcooked your brisket. Acorrding to judging handbook recommendations, brisket meat should have slight elasticity yet pull apart under slight pressure. You want to avoid crumbling or shredding. :licking:
I wonder how it would have been taking it right off the smoker and
serving it, instead of waiting until the next day. I don't plan on ever being
judged other than by those who enjoy it!!
   / Holiday Smoking, YUM #9
I was wondering myself about that, as you continue cooking after removal an then the reheat. As long as you guys liked it, thats all that counts. I was just mentioning it for informations sake. Have you tried any fish yet? We did a half salmon last fall and it was amazing!
   / Holiday Smoking, YUM #10
I used to have briskets fall apart or shred when I tried to slice them, so I've gone to the electric knife and that solved that problem
   / Holiday Smoking, YUM #11
Pull the brisket off the heat at the end wrap in foil, put in a cooler full of towels or newspaper for insulation value and let it set for 60-90 minutes. It will slice better and retain more of the juices.
I'm getting hungry just writing this.
We're not big fish fans here, tried chicken last summer, but
over smoked it, at least we felt it was.
I'll have to try another one when we can eat it the same day,
and let it set for a bit.
amazingly, if i do ribs, i just wrap them in foil and don't even
bother with the smoke per say, a good rub, low and slow indirect
heat, and they come out awesome also.
   / Holiday Smoking, YUM #13
Ive had the same issue with chicken, it gets fall apart tender real quick. I think im going to try that rib route next, but a bit different. Was going to let them smoke at 225 for 3 hrs then remove and par broil over apple cider in the oven for the remaining 4-5 hrs then a quick toss on the grill with sauce before serving... Somethings got to work sooner or later! You should steal that pork from your wifes crock pot and get those butts on the smoker, thats bbq blasphemy!! :laughing: One thing I did that I reccomend to everyone now is to get one of those vacuum food savers. I got the cheap deal from kmart and its great for freezing all of the usually plentiful smoker leftovers.
yea, that's been discussed!
:D
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2009 Hyundai Sonata Sedan (A59231)
2009 Hyundai...
Spreader Attachment (A56859)
Spreader...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
