Holes in FEL bucket for water drainage
   / Holes in FEL bucket for water drainage #1
mhalla
Bloomington, Indiana
John Deere 2210
<font color="green">Do any of you drill holes in the bottom of your FEL buckets to provide for water drainage?
Is this a bad idea?
When I remove my FEL it unfortunately has to sit outside and sometimes rainwater begins to accumulate in the bucket. I thought If I put some drain holes in the bucket bottom that would keep the rainwater from collecting. Leaving the bucket tipped forward to keep the water out doesn't work when it comes time to detach or re-attach the bucket.
I suppose I could just cover the FEL with a tarp but then I would have to tie it up or do something to keep the tarp from blowing away. If the tarp were not taut I suspect that the bucket would still collect water but it would be held in the collapsed part of the tarp.
Any thoughts about drilling holes?
Mike </font>
   / Holes in FEL bucket for water drainage #2
I don't see how 1 or 2 holes would hurt, as many of us have drilled a couple of 1/2" holes in the sides of the bucket to attach a toothbar (bigger machines have a half dozen holes in the cutter bar to accomodate their toothbars). I've never noticed any dirt pouring out of the holes when the toothbar is removed.
I would think you could easily get away with 2 or 3 holes that are 1/8" or 1/4" diameter if all you're looking for is water drainage. I can't see how they'd cause problems, and if you were needing to move liquid, or fine sand, with the FEL, then it would be easy to plug the holes for those jobs.
   / Holes in FEL bucket for water drainage #3
Mike,
Mine came with holes from the factory so I'd think it's OK.
I think mine are almost 1/2" diameter.
Brian
   / Holes in FEL bucket for water drainage #4
I'd say that if you need them there, then put them there. I would go with at least 1/2" holes and get some rubber plugs from the hardware store just in case you need to water something a ways from the house.
   / Holes in FEL bucket for water drainage #5
Sounds like a good idea to me, and if I do it (just may) they will be 1/2" or at least 3/8"'s. I did this with a pickup, to drain the box and found that 1/4" holes just didn't seem to do the job (plugged easily with debris and tree seeds).
   / Holes in FEL bucket for water drainage #6
Drill them the same size as a transom plug in a boat
   / Holes in FEL bucket for water drainage #7
mhalla,
Why can't you tip the bucket forward? I did this with my 755 and do it with my 2210 with no problem (I still cover the loader with a tarp attached with bungee cords to protect the hydraulic cylinders etc).
   / Holes in FEL bucket for water drainage #8
One downside, as someone else up-thread said, if you wanted to carry water in the FEL, which I do from time to time. but another is if you want to mix concrete in the bucket, then any plug you used would get in the way of using the mason's hoe to mix with.
Personally, I like having a water tight bucket.
Cliff
   / Holes in FEL bucket for water drainage #9
</font><font color="blue" class="small">( mhalla,
Why can't you tip the bucket forward? I did this with my 755 and do it with my 2210 with no problem (I still cover the loader with a tarp attached with bungee cords to protect the hydraulic cylinders etc). )</font>
My concern with tipping the bucket forward is that the hydraulic rams are then exposed to the weather. I would rather have a rusty bucket than rusty hydraulic rams.
Bill Tolle
   / Holes in FEL bucket for water drainage #10
<font color="blue"> My concern with tipping the bucket forward is that the hydraulic rams are then exposed to the weather. I would rather have a rusty bucket than rusty hydraulic rams.
</font>
I agree. Dragging rusty dirty rams back into the cylinders sure won't do the seals any good.
Don
2017 Dodge Charger (A53424)
2017 Dodge Charger...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
