Hole digger won't dig- ?
/ Hole digger won't dig- ? #21
I don't know if this is a problem to be solved or a solution to the problem in this thread, but here goes. I have an old Farmall M with a 3ph conversion and 2 way hydraulics. The conversion operates from a two way hydraulic cylinder. Recently, I found a 3ph post hole digger at an auction, but have not had a reason to try it out yet. I keep reading about applying downward force to the digger in order to get it to dig. Wouldn't the two-way hydraulics accomplish this by pushing down on the 3ph and thereby helping the auger to dig?
Thanks,
Tom
/ Hole digger won't dig- ? #22
I do all of my post hole digging in the spring;) I have hardpan clay about 18 inches below the topsoil and I start all of the post holes by hand with a shovel. I dig a hole the same diameter as the auger and dig below the grass roots. Otherwise the roots plug the teeth and auger point won't pull down into the ground. I have to pull the roots out of the teeth. I then replace the teeth after 40 or 50 holes and it works like new again. I've tried sharpening the teeth but doesn't seem to work as good as new ones. I would be hesitant to apply too much down pressure to a 3 pt. auger that was not designed to handle that kind of stress on the gearbox. I scrambled the gears on one auger after the cast arch inside the gearcase that supports the input shaft's inner bearing snapped from excessive down pressure. A hydraulic auger attachment on a skid steer is the ticket for sure. I have ordered a skid steer QA plate for the loader on my JD 5425, and maybe some day I'll invest in a hydraulic auger and attach it to the FEL. Does anyone else do this already? My only concern is that a spotter is needed to direct the placement of the auger point since my guess is that the driver can't see the mark on the ground in front of the tractor.:confused:
/ Hole digger won't dig- ? #23
I have a 3 point PHD and just finished digging 13 holes for my new pole barn in the same red clay. I am about 50 miles south of Hillsborro. The clay is from 1.5 to 2.5 feet below ground and I have sandy loam with good costal grass. The PHD goes down to the clay in seconds and then stops. I don't live there and so only can do this on weekends. One time it had just rained and it dug down a lot better. So the next hole, I added about 2 gallons of water after it hit the clay. It dug through the clay really fast until the auger filled up with clay and wouldn't convey it out of the hole. It took a lot of effort to get it off, enough that I went back to a dry hole the next time. Maybe the answer is some water but not too much? I have also due a few holes where I did not hit clay and instead of digging for an hour or so to get 3.5 feet, it digs it out in seconds so it isn't the auger or the bits, just this really tough red brick clay.
/ Hole digger won't dig- ? #24
A different tip could make all the difference in the world. In woodworking terms, it's like the difference between drilling with a forstner bit verses a self feeding auger bit.
WELL...I got the hole in the ground and all is well...:)
Here is what we did :
First we sharpened the blades at the bottom, which we were told are too worn and now too short.
Then we bought a very long 1" dia. bit and placed it in my DeWalt HD Cordless Drill. Lowered the POD and drilled a shallow hole with the tractor and POD(all the time wishing the POD would just go down another 3 1/2" feet :rolleyes: )
We then drilled the center of the whole as deep as we could with the 12" long bit with the cordless drill.
Then we attached (wrachet straps) a 4" x 4" x 10 feet treated post onto the POD with it hanging off the back, lowered the POD and began to drill. At the same time two people pulled down on the 4x4 post hanging off the back.
OSHA would not approve. I had my hand on the PTO drive handle if a problem occured.
We had to stop and clean the hole a few times but the drilling went very quick this way. One other thing I did is that when it appeared the hydraulic arms would lower no more, I tilted my bucket down and raised the front of the tractor. This shoved the POD into the whole even further.
It worked for me.
For the future I plan to buy new blades for the POD and weld a basket onto the POD to add weight.
/ Hole digger won't dig- ? #26
Glad you got it done.
If you keep using the PHD that way, be sure to update your will so the executor will know to update us at TBN on the progress ;)
jb
/ Hole digger won't dig- ? #27
We have HARD clay. 20 yrs ago, when we moved here, I rented a tractor and PHD to put in a fence. From what I know now, the digging teeth must have been shot. We spun and spun it, adding weight--nothing. Some holes were only 6" deep.
We tried filling them with water and letting it sit overnight. Next morning, the holes were still level full of water.
Fast forward to now. I have a Bota and PHD. At idle, it will sink a hole 30" deep in mere seconds. New teeth are the ticket.
ron
/ Hole digger won't dig- ? #28
It worked for me.
I gotta ask, who were the two people who hung onto a timber post while a PHD was twirling it around?? Surely they had to be family, I can't imagine a neighbor or a freind agreeing to this. Also FWIW, shakes head, I think you are crazy. Now don't take it as an insult or a slam, it is said in the, shakes head and mumbles tone, "Man those people are crazy"
/ Hole digger won't dig- ? #29
Habits, once established are hard to break. You had trouble getting the auger to go down but there are many other users who have had the auger catch and drill down so fast that it screwed itself into the ground in a split instant. Should this happen with two dudes doing pull-ups on a 4x4 post, the outcome might not be so happy. The next hole you drill with different climatic and spot soil conditions might not be so predictable.
/ Hole digger won't dig- ? #30
I am one of those that drilled with the PHD and got it stuck. (with a Ford 1100). Tractor sure could have used some front end weight to help llift it out, no wait, the hydraulics wouldn't pick it up anyway, so I was just in trouble. Time to break out the shovel, lol!!
David from jax
/ Hole digger won't dig- ? #31
Sandman- BTDT, next time just put a pipe wrench on the auger, and twist left, it'll back right out! Turn the pto off and pull up on the hyd, when you are doing the wrench trick, otherwise you'll be a Darwin candidate!:D
/ Hole digger won't dig- ? #32
Those augers are dangerous, and no hole in the universe is worth losing an arm, leg or life. Replace the cutting blades so it will work the way it was designed to work.
/ Hole digger won't dig- ? #33
I am only a weekend warrior and after I had 3 of 4 holes that needed soaking, I invested in a hydraulic down pressure kit. I just don't have the time to waste on trying to dig holes. When I need a hole dug, it needs to be dug now, not in a few hours or even the next day.
/ Hole digger won't dig- ? #34
Tell us where you got your down pressure kit and, if possible, post a picture of your setup. You can't keep good information like this to yourself.:D
/ Hole digger won't dig- ? #35
I have a Land Pride PD35 post hole digger and bought the Land Pride Hydraulic down pressure kit. here's a couple of pictures.
/ Hole digger won't dig- ? #36
G McCall said:
Soil was not frozen and there was no rock or obstructions in the hole. I would call the soil a reddish clay soil that seems to be sandy when it is dry.
I even moved several feet over to see if it would be any easier to dig.
My country place where I was trying to dig is in the Hillsboro Texas area.
I could dig with a shovel very slowly. Just hard digging.
I am not far from you and have the same red clay. However, we are close to a creek and the clay is always moist. I run the tractor at just above idle and take small bites. If I go too fast I will stall the engine. Takes me 10-15 minutes per hole.:)
/ Hole digger won't dig- ? #37
Great info though old !! Am in the same boat. with a Danuser PHD wont go beyond 18in, will try the water trick & also inspect on the bit ends.
/ Hole digger won't dig- ? #38
To add to this old but still useful thread, check the angle of the cutting edge.
Here is a diagram of one I examined in a store. The angle was wrong for that auger. This would be a dirt polisher on hard ground.
Bruce
/ Hole digger won't dig- ? #39
I am worried about this issue! Am looking at post hole diggers (PHDs) and Danuser is the only one I've come across that offers auger bits for different types of soils. That makes sense to me. Does it matter? I don't know, but it seems weird that all economy and most other post hole diggers seem to offer basically the same plain augers, just in different widths.
I wonder if some of those having trouble might try a Danuser auger on their PHD. You'd have to make sure it fits in advance, of course.
My tractor is a 25.5 hp Kubota B2601, so compact. Our soil here is tight clay full of rocks—shale. I mean all sizes of shale, which is formed from compressed clay. And then there are solid shale shelfs. Now nothing I can use will go through a shelf of rock. But I need something to deal with small, medium, and big rocks above those solid shelves. Realistically I guess it would wallow them out. Trying to dig footings here, you are not going to have a nice straight trench. When you hit the edge of a big rock, it gets pulled into the trench and leaves a big hole in the trench's side.
My past experience was with an old PHD, unknown brand but sturdy, and a 33 hp JD970. It did great but our soil was not rocky. I also had a post pounder that worked well. Here, it takes some kind of pre-drilling to drive a post, from what I've been told. The rocks are unreal. To plant a small tree or bush, I have learned to bring a pick as well as a shovel.
So . . . is finding an auger made for such soil important? Does anyone offer this besides Danuser?
Here are the choices for Danuser's 20/40 PHD from their web site; the "Hole Digger Head" mentions shale:
Plain Edge
For digging in dirt, clay, sod, and other light-duty conditions.
Features:
Available in 40”, 52”, and 72” lengths for PTO diggers, and Models 8300, 8800, and 8900 hydraulic drives.
(click to see available auger bits)
Serrated Edge
For digging in compact soils, light tree roots, and dry soil.
Features:
Hole Digger Head
For digging in clay, caliche, shale, mixed limestone, frozen ground, and light rock. The most aggressive design offered.
Features:
Stepped (plain and serrated edges)
Stepped tree planting auger for bulb type trees.
Features:
Available in 33” and 40” lengths for PTO diggers, and Models 8300, 8800, and 8900 hydraulic drives.
/ Hole digger won't dig- ? #40
Incidentally, a lot of posts in this old thread mention using water to soften the soil. A fencer whose video I watched on YouTube says the trick is water and Bentonite. That's a natural, volcanic clay sometimes used to seal pond bottoms. Somehow it melds with the existing dirt or something and the auger goes right down.
I found it here . . .
New/Unused 1in ALR Impact Wrench (A61166)
New/Unused 1in ALR...
KUBOTA MX4800 TRACTOR (A62130)
KUBOTA MX4800...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A62130)
UNUSED IRANCH...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter with PTO (A61166)
New/Unused...
2006 Case IH SPX3310 Sprayer (A63109)
2006 Case IH...
